Hi @amarcoc
Regarding saving the state:
I thought I'd use the features attributes to store a simple boolean value in it for it's suppressed state.
For some reason though I couldn't create an attribute with boolean value, so i had to make it a string. I don't know why because I think it should work with ValueTypeEnum.kBooleanType.
Anyways,
this rule stores a string "True"/"False" as an attribute in the feature:
For Each oFeature As PartFeature In ThisDoc.Document.ComponentDefinition.Features
If oFeature.Name.Contains("DXF") = False Then
Dim oAttributeSet As AttributeSet
Dim oAttribute As Inventor.Attribute
If oFeature.AttributeSets.NameIsUsed("SuppressedInfo")
oAttributeSet = oFeature.AttributeSets.Item("SuppressedInfo")
Try
oAttribute = oAttributeSet.Item("Suppressed")
oAttribute.Value = If (oFeature.Suppressed, "True", "False")
Catch
If oAttributeSet Is Nothing Then MsgBox("hejhejhej")
oAttribute = oAttributeSet.Add("Suppressed", ValueTypeEnum.kStringType, If (oFeature.Suppressed, "True", "False"))
End Try
Else
oAttributeSet = oFeature.AttributeSets.Add("SuppressedInfo")
End If
oFeature.Suppressed = True
End If
NextThen to restore the features use this rule:
Try
Dim oSuppressed As String = oFeature.AttributeSets.Item("SuppressedInfo").Item("Suppressed").Value
oFeature.Suppressed = If (oSuppressed = "True", True, False)
Catch
End Try
End If
NextHope it helps
EDIT: I forgot to add your UpperCase improvement. Don't forget to add it to the code again
