iLogic - Sort sheets by sheet name in open drawing
GKPByDesign
GKPByDesign
I work with massive drawing files sometime over 200 pages in one file, (while I know people don't like this, please reframe from comments about doing one file and multiple sheets compared to many files and one sheet) is there a way to re-order my sheets base on the sheet name? rather than having to drag each each page individually.
Sergio.D.Suárez
Hi, try this rule below. I think it does what you need
Sub Main ()
On Error Resume Next
Dim drawingDoc As DrawingDocument = ThisDoc.Document
Dim Sheet As Sheet = Nothing
Dim sheetsList As New List(Of Sheet)
Dim BrowserPane As BrowserPane = drawingDoc.BrowserPanes.Item("Model")
For Each Sheet In drawingDoc.Sheets
	sheetsList.Add(Sheet)
Next
sheetsList.Sort(AddressOf Comparer)
For Each Sheet In sheetsList
	Dim sheetNode As BrowserNode = BrowserPane.GetBrowserNodeFromObject(Sheet)
	Dim bottomNode As BrowserNode = BrowserPane.TopNode.BrowserNodes.Item(BrowserPane.TopNode.BrowserNodes.Count)
	BrowserPane.Reorder(bottomNode, False, sheetNode)
Next
End Sub
I hope it is useful for you. regards
Please accept as solution and give likes if applicable.
I am attaching my Upwork profile for specific queries.
Sergio Daniel Suarez
Mechanical Designer
| Upwork Profile | LinkedIn
GKPByDesign
Error on Line 12 : 'Comparer' is a type and cannot be used as an expression.
Sergio.D.Suárez
Sub Main ()
Next
Next
End Sub
Private Function Comparer(x As Sheet, y As Sheet) As Integer
	Return String.Compare(x.Name,y.Name)
End Function
Excuse me, I am missing the function below everything, greetings!
Mechanical Designer
Josh_Hunt
Thank you @Sergio.D.Suárez
This worked for me also... however do you know a method that works without using BrowserPane?
BrowserPane is not available in InventorCoreConsole/Forge.
Josh Hunt
M_S_ALDT2
Hi, so I have been making a similar code, when i came across yours. the problem is when there is over 100 sheets, or if the part numbers in this case end in 100, 101, etc it then goes 1 to 10 then 100, 101, 102....109, then 11 then 110, 111, 112, etc... and mixes up the numbers. is there a way to avoid this.
d_eckel
Hi, a fast idea:
Get length of the sheetname and insert one 0 for len(SHEETNAME)=2 and two 0 ("00") for len(SHEETNAME)=1 --> sort sheets --> delete zeroes at the beginning of the sheetnames.
