iLogic Sketch Redefine.
I've tried to use "sketch.redefine" syntax according to steps pre described here:
https://knowledge.autodesk.com/support/inventor-products/learn-explore/caas/CloudHelp/cloudhelp/2014...
but It doesn't work and I don't know why.
Below the snippet of code I've made:
SyntaxEditor Code Snippet
Dim oDoc As PartDocument
oDoc = ThisDoc.Document
Dim oDef As PartComponentDefinition
oDef = oDoc.ComponentDefinition
Dim oSketch As PlanarSketch
oSketch = oDef.Sketches.Item(1)
Sketch.Redefine(oSketch.Name,"P�aszczyzna XY","Punkt �rodkowy","X",AxisIsX := True,NaturalAxisDirection:= True)
The idea is to check and redefine existing sketch on the XY plane.
Thanks in advance for any help.
Tomek
Replies (14)
clutsa
Sketch.Redefine(oSketch.Name,"P�aszczyzna XY","Punkt �rodkowy","X", True, True)
I'm guessing the the last two inputs are optional and only need the boolean value. That's just a guess though.
If I've helped you, please help me by supporting this idea.
Mass Override for Each Model State
Custom Glyph Icon for iMates
dgreatice
hi,
did you try to redefine manually? and are sketch still healthy? if no, code will still throw a error.
Please use the ACCEPT AS SOLUTION or KUDOS button if my Idea helped you to solve the problem.
Autodesk Inventor Professional Certified 2014
It doesn't throw any error and that is strange. I run the rule and just nothing happens.
I'm not sure If I understood the code well, could anybody let me know how originName and planeName should be defined? Specialy I'm not sure about the originName.
Thanks for any help.
Regards
Tomek
dgreatice
can you share you file?
Attached You'll find the file with rule within.
My idea was to create the rule which will check if first sketch was made on XY Plane and if wasn't to redefine sketch on XY Plane automatically.
Tomek
dgreatice
try this:
    Dim oApp As Application
    Dim oPD As PartDocument
    Dim oPCD As PartComponentDefinition
    Dim oSkt As Sketch
    Dim oXY As WorkPlane
    oApp = ThisApplication
    oPD = oApp.ActiveDocument
    oPCD = oPD.ComponentDefinition
    oXY = oPCD.WorkPlanes.Item("XY Plane")
    oSkt = oPCD.Sketches.Item("Szkic2")
    If oSkt.PlanarEntity Is oXY Then
    Else
        oSkt.PlanarEntity = oXY
    End If
dgreatice
Update for make you first sketch full constraints
    Dim oSkt As Sketch
    Dim oCentP As WorkPoint
    Dim oSktPt As SketchPoint
    oCentP = oPCD.WorkPoints.Item(1)
    If Not oSkt.PlanarEntity Is oXY Then
    End If
    Set oSktPt = oSkt.SketchPoints.Item(1)
    On Error Resume Next
    Call oSkt.AddByProjectingEntity(oCentP)
I've tried both and it still doesn't work.
dgreatice
strange,
showing some error?
my code work well
dgreatice
Ok, now I can see the problem. U've used direct vba syntax. I need to adjust the code for direct iLogic syntax.
Is there any simple way to do this? I've tried like this:
    Dim oSkt As Sketch
    oPD = ThisApplication.ActiveDocument
    End If
    'Call oSkt.AddByProjectingEntity(oCentP)
but it gives me an error at the end.
I'd like to implement the code into a bigger iLogic rule.
Tomek
clutsa
    Dim oSkt As PlanarSketch '<------
    End If
"PlanarEntity" isn't a member of 'Sketch' but is a member of 'PlanarSketch' which is derived from 'Sketch'.
dgreatice
I don't know about that. maybe still member of Sketch but Hidden? because when I use VBA local window, it show in tree, but not show in quick suggestion member.
amichaudJ6E3R
Hi, I am trying to achieve something similar but using geometry names?
I need to dynamically redefine a sketch because if my user is changing the shape of the part, the face where the sketch is assigned to disappear. Is it possible to assign a name to that face, and a name to the other face I want to use, and redefine a sketch with those names using a condition?
I've tried the code above by modifying it to what I thought would work, no success there. Is what I want to achieve completely far-fetched?
