iLogic script to calculate number of specific kCustomLineType
mallorn
mallorn
Is there a chance to calculate, in the sketch, number of curves with a special line type i.e.: "ACAD_ISO02W100"?
In the below iLogic script I'm able to calculate all the curves with "kCustomLineType", but I need to know how many lines are with above given type...
Dim oDoc As Document = ThisApplication.ActiveDocument
Dim oSketch As Sketch
oSketch = oDoc.ComponentDefinition.Sketches.Item(1)
'Dim linesCount As Integer
linesCount = 0 ' ******* must be a parameter *******
Dim i As Double
    For i = 1 To oSketch.SketchLines.Count
        If oSketch.SketchLines.Item(i).LineType.ToString = "kCustomLineType" ' "ACAD_ISO02W100" needed
            linesCount = linesCount + 1
        End If
    Next i
Tomasz Malinowski
chandra.shekar.g
Autodesk Support
Autodesk Support
@mallorn,
Can you please provide Inventor file which contains custom line (ACAD_ISO02W100) to test?
Please make sure that files are non confidential.
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Autodesk Developer Network
mallorn
No problem,
You can get the custom line types directly from Inventor standard database also (right clicking on curve properties):
Tomasz Malinowski
chandra.shekar.g
Autodesk Support
Autodesk Support
@mallorn,
Try below iLogic code to count number of custom line type ("ACAD_ISO02W100").
Dim oName As String
Dim oDesc As String
Dim i As Double
	   Call oSketch.SketchLines.Item(i).GetCustomLineType(oName, oDesc)
	   If oName = "ACAD_ISO02W100" Then
	   End If
    End If
Next i
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
