iLogic SaveAs Autocad DWG only one sheet
josiah_pekary
josiah_pekary
I would like to know what the illogic code is to save an inventor drawing as an AutoCAD .dwg. However I only want to save the one sheet I specify. The current code I have below will save all the sheets, I want to specify which sheet it saves.
Version:1.0 StartHTML:00000145 EndHTML:00002174 StartFragment:00000294 EndFragment:00002142 StartSelection:00000294 EndSelection:00000294SyntaxEditor Code Snippet
Dim doc As DrawingDocument
doc = ThisApplication.ActiveDocument
doc.Sheets.Item("1202_GLASS PRINT:30").Activate
ThisDoc.Document.SaveAs("H:\EngCustomProducts\CustomGlass\" & Parameter("1202-GateASM.iam.JobNo") & "-MG12CF.dwg" , True)
JamieVJohnson2
When working this problem by hand, there is a checkbox in the options wizard, that allows you to select a specific sheet or sheets.  When I saved that configuration into a *.ini file, I noticed an option that says "ALL SHEETS=No" under [EXPORT DESTINATION], however that file did not mention the sheet I selected.  So at least I know there is access to this option.
In this code, I export with a bit more direct control over the actual translator.  I suspect your answer lies in the oNameValueMap including something for the sheets to be printed.
    Public Sub ExportACAD(settingsFile As String, isDWG As Boolean)
        Dim invApp As Inventor.Application = TTSInventorTools.GetInventorApplication
        ' Set a reference to the DWG translator add-in.
        Dim oDWGAddIn As TranslatorAddIn = Nothing
        'USE DWG OR DXF FIND "DESTNATION DXF=Yes or No" in ini file (text file)
        Dim ClassID As String = "{C24E3AC4-122E-11D5-8E91-0010B541CD80}"
        Dim ext As String = ".dxf"
        If isDWG Then
            ClassID = "{C24E3AC2-122E-11D5-8E91-0010B541CD80}" ' = DWG TRANSLATOR
            ext = ".dwg"
        Dim i As Long
        For i = 1 To invApp.ApplicationAddIns.Count()
            If invApp.ApplicationAddIns.Item(i).ClassIdString = ClassID Then
                oDWGAddIn = invApp.ApplicationAddIns.Item(i)
                Exit For
        Next
        If oDWGAddIn Is Nothing Then
            MsgBox("DWG add-in not found.", MsgBoxStyle.SystemModal)
            Exit Sub
        ' Check to make sure the add-in is activated.
        If Not oDWGAddIn.Activated Then
            oDWGAddIn.Activate()
        ' Create a name-value map to supply informationto the translator.
        Dim oNameValueMap As NameValueMap
        oNameValueMap = invApp.TransientObjects.CreateNameValueMap()
        ' Create the name-value that specifiesthe ini file to use.
        Call oNameValueMap.Add("Export_Acad_IniFile", settingsFile)
        ' Create a translation context and define that we want to output to a file.
        Dim oContext As TranslationContext
        oContext = invApp.TransientObjects.CreateTranslationContext()
        oContext.Type = IOMechanismEnum.kFileBrowseIOMechanism
        ' Define the type of output by specifying the filename.
        Dim oOutputFile As DataMedium
        oOutputFile = invApp.TransientObjects.CreateDataMedium()
        oOutputFile.FileName = ACADFilePath & "\" & Name & ext
        ' Call the SaveCopyAs method of the add-in.
        If Not System.IO.File.Exists(oOutputFile.FileName) Then
            System.IO.Directory.CreateDirectory(System.IO.Path.GetDirectoryName(oOutputFile.FileName))
            oDWGAddIn.SaveCopyAs(docINV, oContext, oNameValueMap, oOutputFile)
    End Sub
Not a complete answer but likely a point into the correct direction.
Jamie Johnson : Owner / Sisu Lissom, LLC https://sisulissom.com/
JamieVJohnson2
Searching the Programmers API, for these options to be spelled out, use the Index and search for Translator Options page (or ShowSaveCopyAsOptions Method\TranslatorAddIn Object\Translator Options in Remarks - how I found it).
Scroll down to the Export options for DWG and Definition of Export Values, and Sheets is listed as an option to manipulate.
josiah_pekary
Thank you this works.
