iLogic rules
Cosmin_V
iLogic rules
Cosmin_V
I have an Assembly which have iLogic rules.
If I make a Copy Design whit Vault and add a suffix or a prefix to the original name the rules are dont run anymore.
Can I add a rule which update the rules if name is change?
Or how can I fix it?
Thank You very much...
Replies (11)
Sergio.D.Suárez
Hi, welcome to the forum, you should open the assembly and in your rules you should not put the name to identify a component in an assembly, because the name is what will change later. For instance, suppose you have a rule like this (they compared it recently in another forum thread)
Parameter("Flange_DIN.ipt","DN") = DN_DIN
you should identify the component in another way, for example, through the occurrence item.
Then I leave you a code so you can identify the item that defines your component in the assembly, each item has a component
    Dim oDoc As AssemblyDocument
    oDoc = ThisApplication.ActiveDocument
    Dim oDef As AssemblyComponentDefinition
    oDef = oDoc.ComponentDefinition
	For i As Integer = 2 To oDef.Occurrences.Count
	    Dim oOcc As ComponentOccurrence = oDef.Occurrences.Item(i)
		MessageBox.Show("Item Number: " & i & vbCrLf & "Occurrence Name: " & oOcc.Name )
	Next
For instance, if for your part "Flange_DIN.ipt" you  find that it corresponds to item 3 . you should change the line
by the lines (  you must completely define the syntax oDef at the beginning of the rule)
Dim oFlangeDIN As ComponentOccurrence = oDef.Occurrences.Item(3)
Parameter(oFlangeDIN.name,"DN") = DN_DIN
If you identify each component through the item, you can rename them and the rules will continue to work correctly.
I hope it will help you solve your problem
Please accept as solution and give likes if applicable.
I am attaching my Upwork profile for specific queries.
Sergio Daniel Suarez
Mechanical Designer
| Upwork Profile | LinkedIn
Cosmin_V
I don´t understand exactly your explanation, and where are they com from..:(
my rules are like this.
Format:HTML Format Version:1.0 StartHTML: 165 EndHTML: 30822 StartFragment: 314 EndFragment: 30790 StartSelection: 314 EndSelection: 314
If CC50_centricoate= 1 Then
Parameter("CC50 centricoate FP foundation:1", "foundation")=1
End If
If Powder_feeder_Left=1 ul Then
MultiValue.SetListInComponent("CC50 powder feeder L:1", "Powder_feeder_Left", 0, 1)
Parameter("CC50 powder feeder L:1", "Powder_feeder_Left") = 1 ul
End If
If Powder_feeder_Left=0 ul Then
Parameter("CC50 powder feeder L:1", "Powder_feeder_Left") = 0 ul
End If
If Powder_feeder_Left_Fantom=1 ul Then
MultiValue.SetListInComponent("CC50 powder feeder L fantom:1", "Powder_feeder_Left_Fantom", 0, 1)
Parameter("CC50 powder feeder L fantom:1", "Powder_feeder_Left_Fantom") = 1 ul
End If
If Powder_feeder_Left_Fantom=0 ul Then
Parameter("CC50 powder feeder L fantom:1", "Powder_feeder_Left_Fantom") = 0 ul
End If
If Powder_feeder_Right=1 ul Then
MultiValue.SetListInComponent("CC50 powder feeder R:1", "Powder_feeder_Right", 0, 1)
Parameter("CC50 powder feeder R:1", "Powder_feeder_Right") = 1 ul
End If
If Powder_feeder_Right=0 ul Then
Parameter("CC50 powder feeder R:1", "Powder_feeder_Right") =0 ul
End If
If Powder_feeder_Right_Fantom=1 ul Then
MultiValue.SetListInComponent("CC50 powder feeder R fantom:1", "Powder_feeder_Right_fantom", 0, 1)
Parameter("CC50 powder feeder R fantom:1", "Powder_feeder_Right_fantom") = 1 ul
End If
If Powder_feeder_Right_Fantom=0 ul Then
Parameter("CC50 powder feeder R fantom:1", "Powder_feeder_Right_fantom") = 0 ul
End If
If Door_Fantom=1 ul Then
MultiValue.SetListInComponent("CC50 Door:1", "Door_Fantom", 0, 1)
Parameter("CC50 Door:1", "Door_Fantom") = 1 ul
End If
If Door_Fantom=0 ul Then
Parameter("CC50 Door:1", "Door_Fantom") = 0 ul
End If
Powder_feeder_Left_Fantom = 0 ul
Parameter("CC50 powder feeder L fantom:1", "Powder_feeder_Left_Fantom")= 0 ul
ElseIf Powder_feeder_Left_Fantom = 1 ul Then
Parameter("CC50 powder feeder L fantom:1", "Powder_feeder_Left_Fantom")= 1 ul
End If
Powder_feeder_Right_Fantom = 0 ul
Parameter("CC50 powder feeder R fantom:1", "Powder_feeder_Right_fantom")= 0 ul
ElseIf Powder_feeder_Right_Fantom = 1 ul Then
Parameter("CC50 powder feeder R fantom:1", "Powder_feeder_Right_fantom")= 1 ul
End If
Sergio.D.Suárez
What I was trying to tell you is that you must change all the names that I have crossed out in your code, and look for defining each component through the item
End If
End If
End If
End If
End If
End If
End If
End If
End If
End If
End If
End If
End If
 It's hard work, but it ensures there will be no problems later. Maybe there are other methods this has worked for me pretty well. regards
Mechanical Designer
Cosmin_V
I understend your point, but I don´t understend how and where to make this changes…:(
Jon.Dean
Hi @Cosmin_V,
This issue you describe has been logged with development.
It is a known issue. See the following link.
Which version of Inventor / Vault are you working with?
Cheers.
Jon.
Jon Dean
Cosmin_V
Hi
I see this video before. But in the video it show to create "Action Rules" (min-46).
But I don´t have that function...
I use Vault and Inventor 2016
Sergio.D.Suárez
Can you attach your file here?
Mechanical Designer
Cosmin_V
not that one, but I create a new one...similar.
and Thank again for the help
Sergio.D.Suárez
This is an example. (You attach only the assembly file, its components are missing, so I do not know the parameters of each part)
There is an assembly parameter, when "feeder_L =" ON "" will change the parameter "d0" of the "Cub" part to the value 1.2.
when "feeder_L =" OFF "" the parameter "d0" of the "feeder_L" part is changed to the value 5.
Note how the entry of the part name has been modified, so when you change the name of the file you will not have problems.
Dim oDoc As AssemblyDocument = ThisDoc.Document
Dim oCub As ComponentOccurrence = oDef.Occurrences.Item(1)
Dim oFeederL  As ComponentOccurrence = oDef.Occurrences.Item(2)
Dim oFeederR As ComponentOccurrence = oDef.Occurrences.Item(3)
	MessageBox.Show(oCub.Name)
	MessageBox.Show(oFeederL.Name)
	MessageBox.Show(oFeederR.Name)
If feeder_L = "ON" Then
	Parameter(oCub.Name, "d0") = 1.2
End If
If feeder_L = "OFF" Then
	Parameter(oFeederL.Name, "d0") = 5
End If
Mechanical Designer
Cosmin_V
hmmm....
I tried but some things are still not working. If you still have the patience can you show me again...?
I attach 3 files here
Cosmin_V
and one more
