Ilogic Rule To Mark Textbox on a face with a specific direction for Engraving
9 REPLIES 9
Message 1 of 10
jeanB99VC
955 Views, 9 Replies
Hi There,
I am having trouble to make the Mark for Engraving on the face in the right direction and position.
Sometimes the mark is outside of the geometry. and the rule can't compleet.
This is not always the case.
GOAL:
I want to place the mark for engraving on a picted face at a certain point in a certain direction.
I've tried this to do with a direction vector which i copied from the forum.
Still I can't get it right on several geometries.
Please help me with this.
Sub Main()
'===================== DECLERATIONS ===============================
 '  a reference to the currently active document.
 ' This assumes that it is a part document.
	    Dim oPartDoc As PartDocument
	    	oPartDoc = ThisApplication.ActiveDocument
		Dim oCompDef As PartComponentDefinition
			oCompDef = oPartDoc.ComponentDefinition
  ' Set a reference to the transient geometry object.
    	Dim oTransGeom As TransientGeometry
    		oTransGeom = ThisApplication.TransientGeometry
		Dim oPartCompDef As PartComponentDefinition
			oPartCompDef = ThisApplication.ActiveDocument.ComponentDefinition
'Find Sketch named already For marking so the user can delete it
	For Each oSketchCheck As PlanarSketch In oPartCompDef.Sketches
		If oSketchCheck.Name = "MarkingSketch" Then
			MessageBox.Show("A sketch named " & oSketchCheck.Name & " already exists. Please Delete this sketch", "Controle op MarkingSketch")
			Return
		End If
	Next
'Select Face and Edges to place the textbox in a certain direction
	Dim oFace As Face = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kPartFaceFilter, "Select Surface to Place Textbox")
	Dim oHorizontalEdge As Edge = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kPartEdgeFilter, "Select Horizontal Edge of Tekeningnummer on Face")
	Dim oVerticalEdge As Edge = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kPartEdgeFilter, "Select Vertical Edge of Tekeningnummer on Face")
'Add Sketch and set sketch origin point to the stopVertex of the FrontEdge, this is where the TextBox starts
	Dim oSketch As PlanarSketch
		oSketch = oPartCompDef.Sketches.Add(oFace, False)
		oSketch.AxisEntity = oVerticalEdge
		oSketch.OriginPoint = oHorizontalEdge.StopVertex
		oSketch.NaturalAxisDirection = True
' ===================== Create a Custom Parameter in Iproperties "Tekeningnummer"======================
		'Creating Custom IProperty with filenumber in it calling it Tekeningnummer
			iProperties.Value("Custom", "Tekeningnummer") = ThisDoc.FileName(False) 'false = without extension
			iProperties.Value("Custom", "Tekeningnummer") = (Left(ThisDoc.FileName(False),14))
		'Creating a UserParameter Where the Tekeningnummer value Is put In
		Dim PropValue As String = iProperties.Value("Custom", "Tekeningnummer")
		'updates the user-defined Text Parameter
		TagName = PropValue
'================================ Create a textbox in the Sketch to place the Iporp Tekeningnummer ====================
		'     Create Text With simple String As Input.  Since this doesn't use
		'     any Text Overrides, it will Default To the active Text Style.
			Dim oTG As TransientGeometry
		    	oTG = ThisApplication.TransientGeometry
			Dim sText As String
		    	sText = TagName
			Dim oTextBox As Inventor.TextBox
		    	oTextBox = oSketch.TextBoxes.AddFitted(oTG.CreatePoint2d(0.5, 0.5), sText)
'Changing Font and/or size
		Dim dTextSize As Double
			dTextSize = 0.350 ' value is in cm.  equals .125 in
		Dim sTextFont As String
'			sTextFont = "SIMPLEX"
			oTextBox.FormattedText = "<StyleOverride Font = '" & sTextFont & "' FontSize = '" & dTextSize & "'>" & _
				sText & "</StyleOverride>"
'==================== Creating an Objectcollection to be Marked ======================
    Dim oSketchObjects As ObjectCollection
    	oSketchObjects = ThisApplication.TransientObjects.CreateObjectCollection
    ' Get all entities in the sketch
	Dim oSketchText As Inventor.TextBox
    	For Each oSketchText In oSketch.TextBoxes
     	   oSketchObjects.Add(oSketchText)
	Next
'==================== Creating the Mark on the textbox  ======================
    Dim oMarkFeatures As MarkFeatures
    	oMarkFeatures = oCompDef.Features.MarkFeatures
' Get a mark style.
    Dim oMarkStyle As MarkStyle
    	oMarkStyle = oPartDoc.MarkStyles.Item(1)
' Create mark definition.
	Dim oMarkDef As MarkDefinition
		oMarkDef = oMarkFeatures.CreateMarkDefinition(oSketchObjects, oMarkStyle)
' Create a mark feature.
	Dim oMark As MarkFeature
		oMark = oMarkFeatures.Add(oMarkDef)
'Naming the sketch And markfeature For detection In future
		oSketch.Name = "MarkingSketch"
		oMark.Name = "Gravering Tekeningnummer"
Call ZoomAll
oPartDoc.Save
End Sub
Sub ZoomAll
'zoom all, this to be sure the part is in ISOmetrich position saved so it is ISO visible in explorer
	ThisApplication.CommandManager.ControlDefinitions.Item("AppIsometricViewCmd").Execute
End Sub
9 REPLIES 9
Message 2 of 10
JelteDeJong
in reply to: jeanB99VC
maybe you can change the way how you define the sketch. something like this:
Dim orignVertex As Vertex = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kPartVertexFilter, "Select vertex")
Dim testVertex As Vertex = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kPartVertexFilter,
															"Select a 2e vertex that is on a positive point in the sketch")
Dim oSketch As PlanarSketch = oPartCompDef.Sketches.Add(oFace, False)
oSketch.AxisEntity = oHorizontalEdge
oSketch.OriginPoint = orignVertex
'Check if the testVertex has positive coordinates
Dim testPoint As Point2d = oSketch.ModelToSketchSpace(testVertex.Point)
If (testPoint.X <= 0 Or testPoint.Y <= 0) Then
	oSketch.NaturalAxisDirection = False
End If
Jelte de Jong
Blog: hjalte.nl - github.com
Message 3 of 10
jeanB99VC
in reply to: JelteDeJong
Hi Jelte,
Thank you for your quick response. I've tried your code.
I can select a face and the horizontalEdge but I can't select the first vertex. I don't know why ?
Hope you can help me !
Message 4 of 10
jeanB99VC
Hi Jelte.
I now see that the vertex to choose is by two points. I thought a line was ment 🙂
Message 5 of 10
jeanB99VC
Hi Jelte,
I'tried your code but it seems the vertex is not correct an all faces with a certain direction. See attached screenshot.
I'v attached the file i use to test.
Hope the hear from you, Thank you in advance
Message 6 of 10
jeanB99VC
Hi Jelte,
I've attached the file I use to test.
Hope the hear from you, Thank you in advance.
Message 7 of 10
JelteDeJong
The idea was that you select something like this:
The new sketch will be placed on the "plane"
The origin of the sketch will be placed on "1e vertex"
The x-axis of the sketch will be defined by the "horizontal edge"
The axes are then still not defined because it's not defined what is positive and negative from the origin. That will be defined by any point in the positive quadrant of the plane. That's why you need to select the "2e vertex".  The best would be to choose a 2e vertex that is not on one of the axes. Points/vertexes on an axis have the coordinates (0, Y) or (X, 0). If 0 is positive or negative is always a point of discussion therefore you could better select a point that is not on coordinate with 0 for X or Y.
Jelte de Jong
Message 8 of 10
JelteDeJong
I found a bug in the code. Changes are on lines 49 to 50  and 78 to 83. This code will do a better job:
Sub Main()
		Return
	End If
Next
If (testPoint.X <= 0) Then
End If
testPoint  = oSketch.ModelToSketchSpace(testVertex.Point)
Dim positiveQuadrantIsOnPlane = (testPoint.Y >= 0)
' ===================== Create a Custom Parameter in Iproperties Tekeningnummer ======================
iProperties.Value("Custom", "Tekeningnummer") = (Left(ThisDoc.FileName(False), 14))
TagName = PropValue
Dim sText As String
sText = TagName
If (positiveQuadrantIsOnPlane) Then
Else
	oTextBox = oSketch.TextBoxes.AddFitted(oTG.CreatePoint2d(0.5, -0.5), sText)
End If
End Sub
Jelte de Jong
Message 9 of 10
jeanB99VC
Hi Jelte,
Your remark :
 "The best would be to choose a 2e vertex that is not on one of the axes. Points/vertexes on an axis have the coordinates (0, Y) or (X, 0). If 0 is positive or negative is always a point of discussion therefore you could better select a point that is not on coordinate with 0 for X or Y."
Now it is working on every plane in my testpart. I'm going to test it in our workflow and give your last code as solution.
If I find any trouble with it during our engineering I will post it.
Thank you very much for your help!!
Message 10 of 10
jeanB99VC
Hi Jelte and other enthousiasts,
I'm still having trouble selecting any face and than engrave on that face.
I've attached the part which I used. The engraving is on it so you can see which face I choosed.
But I had to open the sketch and rotate the textbox to do so.
Please have a try to use the rule on that face. You will see that the mark can't be placed on that face
I hope you can solve this. Thank you in advance
