iLogic Rule to create description based on dimensions, bounding box, stock number
jmfowler1996
jmfowler1996
This is my way of giving back to the forum.
Thanks for all the help!
I made an iLogic rule to automatically create descriptions for parts.
Here's how it works:
1. Run the rule.
2. You are prompted to select a line of a part in a drawing view.
3. An input pox is diplayed with an overridable default description.
4. Click "OK" and you're done!
The code distinguishes between all of the content center parts in the above list,
and creates a description based on dimensions/bounding box/stock number
If you have any comments on the code, be sure to let me know :slightly_smiling_face:
I've tried to add helpful annotations, but know that I'm really not a coder.
some of this code is just stitched together from other sources.
Here ya go:
    'Code to modify a part's description iPorperty based on shape, created by Jonathan Fowler
    'Works by selecting a line segment from a part in a drawing view.
    'Document declaration
    Dim oDoc As Inventor.Document
    oDoc = ThisApplication.ActiveDocument
    'Prompt user to pick a line segment
    Dim oDrawCurveSeg As DrawingCurveSegment
    oDrawCurveSeg = ThisApplication.CommandManager.Pick _
     (Inventor.SelectionFilterEnum.
      kDrawingCurveSegmentFilter,
      "Select a Drawing Curve")
    'Get the parent DrawingCurve
    Dim oDrawCurve As DrawingCurve
    Try
        oDrawCurve = oDrawCurveSeg.Parent
    Catch ex As Exception
        Exit Sub
    End Try
    'Get the model geometry this curve represents.
    Dim oModelGeom As Object
    oModelGeom = oDrawCurve.ModelGeometry
    'Check to see if the returned object supports
    'the ContainingOccurrence property.
    Dim oOcc As ComponentOccurrence
    Try
        oOcc = oModelGeom.ContainingOccurrence
           'MessageBox.Show("Problem getting occurrence for: " & partName, "iLogic")
    End Try
    'Define model geometry
    Dim oModelGeometry = oDrawCurveSeg.Parent.ModelGeometry
    'Define component definition
    Dim oCompDef As ComponentDefinition
    oCompDef = oModelGeometry.parent.componentdefinition
    'Get part name
    partName = oCompDef.Document.DisplayName
    'Get the drawing view
    Dim oDrwView As DrawingView
    oDrwView = oDrawCurve.Parent
    'Define oPart As String
    oPart = oCompDef.Document.DisplayName & ".ipt"
    'Declare AutoType, the part shape type to be calculated.
    Dim AutoType As String
    'Define Units of Measure
    Dim uom as UnitsOfMeasure = oDoc.UnitsOfMeasure
    'Declare the range box.
    Dim oRB As Box
    Try
        'Get the range box, aligned to part UCS, excluding work geometry.
        For Each sb In oCompDef.SurfaceBodies
            If oRB Is Nothing Then
                oRB = sb.RangeBox.Copy
            Else
                oRB.Extend(sb.RangeBox.MinPoint)
                oRB.Extend(sb.RangeBox.MaxPoint)
            End If
        Next
        MessageBox.Show("Error finding extensions for part: " & partName, "iLogic")
    End Try
    Dim minp As point = oRB.minPoint
    Dim maxp As point = oRB.maxPoint
    Dim AutoName As String
    AutoName = "-"
        InventorVb.DocumentUpdate()
        Try
        oCheckFile = iProperties.Value(oPart, "Project", "Part Number")
        Catch
        MessageBox.Show("Error finding file for part: " & partName, "iLogic")
        Exit Sub
        End Try
        'Get part dimensions
        dp=0
        X = Round(uom.ConvertUnits ((maxP.X - minP.X), "cm", uom.LengthUnits), dp)
        Y = Round(uom.ConvertUnits ((maxP.Y - minP.Y), "cm", uom.LengthUnits), dp)
        Z = Round(uom.ConvertUnits ((maxP.Z - minP.Z), "cm", uom.LengthUnits), dp)
                'MessageBox.Show("Extents: " & X & " : " & Y & " : "  & Z, "iLogic")
        'Sort dimensions largest to smallest
        Thickness = MinOfMany(X, Y, Z)
        Length = MaxOfMany(X, Y, Z)
        Width = X
        If Thickness = X Or Length = X Then
            Width = Y
            If Thickness = Y Or Length = Y Then
            Width = Z
            End If
        End If
        'Get stock number properties (which are sometimes different to actual dimensions)
        Dim stockprops() As String
        Try
            stockprops = Split(iProperties.Value(oPart, "Project", "Stock Number"), "x")
        Catch
        End Try
        Try
        'Use part parameter named "Type", if it exists.
        'This can be used as an override for a part which is being wrongly assessed.
        AutoType = Parameter(oPart, "Type")
            'Test for parameters
            Try
            parametro = Parameter(oPart, "G_NG")
            G_NG = 1
            Catch
            G_NG = 0
            End Try
            Try
            parametro = Parameter(oPart, "G_T")
            G_T = 1
            Catch
            G_T = 0
            End Try
            Try
            parametro = Parameter(oPart, "G_W")
            G_W = 1
            Catch
            G_W = 0
            End Try
            Try
            parametro = Parameter(oPart, "G_ER")
            G_ER = 1
            Catch
            G_ER = 0
            End Try
            Try
            parametro = Parameter(oPart, "G_T1")
            G_T1 = 1
            Catch
            G_T1 = 0
            End Try
            'Compare to expected parameters
            If G_NG = 1 Then
            AutoType = "PFC"
            ElseIf G_T1 = 0 And G_W = 1 And G_ER = 0 And G_T = 1 Then
            AutoType = "RHS"
            ElseIf G_T = 1 And G_W = 0 Then
            AutoType = "CHS"
            ElseIf G_T = 0 And G_W = 0 Then
            AutoType = "RD BAR"
            ElseIf G_T1 = 1 And G_NG = 0 Then
            AutoType = "UC"
            ElseIf G_ER = 1 Then
            AutoType = "RSA"
            ElseIf G_W = 1 And G_T = 0 Then
            AutoType = "F BAR"
            Else
            AutoType = ""
            End If
        End Try
        'Set Shape Type
        If AutoType = "" Then
        'Prompt for manual input - in format "PFC", "F BAR", "RD BAR", "UC", etc.
        oType = InputBox("Treat as:", "Part Type", AutoType)
        Else
        'Use automatically calculated type
        oType = AutoType
        End If
        'Create a default description
        Select Case UCase(oType)
        Case "PLATE"
        AutoName = "PLT " & Thickness & " THK " & Length & " x " & Width
        Case "F BAR"
        AutoName = "F/BAR " & Width & " x " & Thickness
        Case "CHS"
        Try
        AutoName = "CHS " & Parameter(oPart, "G_H") & " OD x " & Parameter(oPart, "G_T") & " WT"
        Catch
        MessageBox.Show("Error getting parameters", "iLogic")
        AutoName = ""
        End Try
        Case "SHS", "RHS"
        Try
        'Distinguish between square and rectangular section
        If Parameter(oPart, "G_W") = Parameter(oPart, "G_H") Then
        AutoName = "SHS " & Parameter(oPart, "G_H") & " x " & Parameter(oPart, "G_W") & " x " & Parameter(oPart, "G_T")
        Else
        AutoName = "RHS " & Parameter(oPart, "G_H") & " x " & Parameter(oPart, "G_W") & " x " & Parameter(oPart, "G_T")
        End If
        Catch
        AutoName = ""
        End Try
        Case "RD BAR"
        Try
        AutoName = "RD BAR DIA. " & Parameter(oPart, "G_H")
        Catch
        AutoName = ""
        End Try
        Case "RSA"
        Try
        AutoName = "RSA " & Parameter(oPart, "G_H") & " x " & Parameter(oPart, "G_W") & " x " & Parameter(oPart, "G_T")
        Catch
        AutoName = ""
        End Try
        Case "PFC"
        Try
        AutoName = "PFC " & stockprops(0) & " x " & stockprops(1) & " x " & stockprops(2)
        Catch
        AutoName = ""
        End Try
        Case "UC", "UB"
        Try
        'Distinguish between collumn and beam
        If Val(stockprops(0)) <= Val(stockprops(1)) Then
        AutoName = "UC " & stockprops(0) & " x " & stockprops(1) & " x " & stockprops(2)
        Else
        AutoName = "UB " & stockprops(0) & " x " & stockprops(1) & " x " & stockprops(2)
        End If
        Catch
        AutoName = ""
        End Try
        Case Else
        AutoName = ""
        End Select
        'Show input box with default description
        oNewDescription = InputBox("Description for '" & partName & "':", "Description Editor", AutoName)
        If oNewDescription = "" Then
        'Cancel if no description is entered.
        MessageBox.Show("Description change cancelled.", "iLogic")
        Else
        'Change part description
        iProperties.Value(oPart, "Project", "Description") = oNewDescription
        'Restart to choose next part
        iLogicVb.RunRule("Dimensions - Individual")
        End If
Replies (15)
jmfowler1996
An update to make it better at recognizing plate.
    'Code to modify a part's description iPorperty based on shape.
    Try
        Exit Sub
    End Try
    Try
    End Try
    'Get part name
    Dim minp As point
    Dim maxp As point
    Dim oRB As Box
    Try
            Else
            End If
        Next
        minp = oRB.minPoint
        maxp = oRB.maxPoint
        Exit Sub
    End Try
    AutoName = "-"
        Try
        Catch
        Exit Sub
        End Try
        dp=0
        Width = X
            Width = Y
            Width = Z
            End If
        End If
        Try
        Catch
        End Try
        Try
            Try
            G_NG = 1
            Catch
            G_NG = 0
            End Try
            Try
            G_T = 1
            Catch
            G_T = 0
            End Try
            Try
            G_W = 1
            Catch
            G_W = 0
            End Try
            Try
            G_ER = 1
            Catch
            G_ER = 0
            End Try
            Try
            G_T1 = 1
            Catch
            G_T1 = 0
            End Try
            Try
            parametro = Parameter(oPart, "G_H")
            G_H = 1
            Catch
            G_H = 0
            End Try
            If G_NG = 1 Then
            AutoType = "PFC"
            AutoType = "RHS"
            AutoType = "CHS"
            ElseIf G_T = 0 And G_W = 0 And G_H = 1 Then
            AutoType = "RD BAR"
            AutoType = "UC"
            AutoType = "RSA"
            AutoType = "F BAR"
            ElseIf G_H = 0 Then
            AutoType = "PLATE"
            Else
            'leave blank if no match is found.
            AutoType = ""
            End If
        End Try
        'Set Shape Type
        Else
        oType = AutoType
        End If
        Case "PLATE"
        Case "F BAR"
        Case "CHS"
        Try
        Catch
        AutoName = ""
        End Try
        Case "SHS", "RHS"
        Try
        Else
        End If
        Catch
        MessageBox.Show("Error getting parameters as " & oType, "iLogic")
        AutoName = ""
        End Try
        Case "RD BAR"
        Try
        Catch
        AutoName = ""
        End Try
        Case "RSA"
        Try
        Catch
        AutoName = ""
        End Try
        Case "PFC"
        Try
        Catch
        AutoName = ""
        End Try
        Case "UC", "UB"
        Try
        Else
        End If
        Catch
        AutoName = ""
        End Try
        Case Else
        AutoName = ""
        End Select
        Else
        End If
jmfowler1996
Another update.
I wish I could just edit my original post, but I don't seem to be able to, so here's the update:
	'Code to modify a part's description iPorperty based on shape. Created by Jonathan Fowler.
    'Dim oDrawCurveSeg As DrawingCurveSegment
	Try
		'MessageBox.Show("No drawing curve found.", "iLogic")
		Exit Sub
	End Try
	Try
    End Try
	'Get part name
	'MessageBox.Show(partName & " selected.", "iLogic")
	Dim minp As point
	Dim maxp As point
	Dim oRB As Box
	Try
			Else
			End If
		Next
		minp = oRB.minPoint
		maxp = oRB.maxPoint
		Exit Sub
	End Try
	AutoName = "-"
		Try
		Catch
		Exit Sub
		End Try
		dp=0
		'Sort dimensions from smallest to largest
		Dim extents As New ArrayList()
		extents.add(X)
		extents.add(Y)
		extents.add(Z)
		extents.Sort()
				'MessageBox.Show("Extents: " & extents(0) & " : " & extents(1) & " : "  & extents(2), "iLogic")
		'Assign dimensions
		Thickness = extents(0)
		Width = extents(1)
		Length = extents(2)
		Try
		Catch
		End Try
		'Get classification for fasteners
		Dim stockclass() As String
		Try
			stockclass = Split(iProperties.Value(oPart, "Project", "Part Number"), "-")
			oClass = stockclass(1)
			oClass = Right(oClass, Len(oClass)-1)
			If InStr(oClass, " ") > 0 Then
			oClass = Left(oClass, InStr(oClass, " ")-1)
			End If
			If Not UCase(Left(oClass, 1)) = "M" Then
			oClass = oClass & """"
			If Not InStr(iProperties.Value(oPart, "Project", "Part Number"), "UNC") = 0 Then
			stand = " UNC"
			End If
			If Not InStr(iProperties.Value(oPart, "Project", "Part Number"), "UNF") = 0 Then
			stand = " UNF"
			End If
			Else
			stand = ""
			End If
		Catch
		End Try
		Try
			'Create a list of parameters to check for.
			Dim paramstocheck As New ArrayList()
			paramstocheck.add("G_NG")
			paramstocheck.add("G_T")
			paramstocheck.add("G_W")
			paramstocheck.add("G_ER")
			paramstocheck.add("G_T1")
			paramstocheck.add("G_H")
			paramstocheck.add("b")
			paramstocheck.add("NLG")
			paramstocheck.add("SW")
			paramstocheck.add("SD2")
			paramstocheck.add("SEWI")
			paramstocheck.add("KOD")
			paramstocheck.add("FAWI")
			'paramstocheck.add("[NEW PARAMETER TO CHECK]")
			'Create a list of parameters found out of those checked.
			Dim params As New ArrayList()
			For Each param in paramstocheck
				'MessageBox.Show("Checking for: " & param, "iLogic")
				Try
					parametro = Parameter(oPart, param)
					params.Add(param)
					'MessageBox.Show(param & " = " & parametro, "iLogic")
				Catch
					'MessageBox.Show(param & " doesn't exist.", "iLogic")
				End Try
			Next
			If params.Contains("G_NG") Then
			AutoType = "PFC"
			ElseIf (Not params.Contains("G_T1")) And params.Contains("G_W") And (Not params.Contains("G_ER")) And params.Contains("G_T") Then
			AutoType = "RHS"
			ElseIf params.Contains("G_T") And (Not params.Contains("G_W")) Then
			AutoType = "CHS"
			ElseIf (Not params.Contains("G_T")) And (Not params.Contains("G_W")) And params.Contains("G_H") Then
			AutoType = "RD BAR"
			ElseIf params.Contains("G_T1") And (Not params.Contains("G_NG")) Then
			AutoType = "UC"
			ElseIf params.Contains("G_ER") Or params.Contains("b") Then
			AutoType = "RSA"
			ElseIf params.Contains("G_W") And (Not params.Contains("G_T")) Then
			AutoType = "F BAR"
			ElseIf params.Contains("NLG") And params.Contains("SW")And params.Contains("SD2") Then
			AutoType = "BOLT"
			ElseIf params.Contains("SW") And (Not params.Contains("NLG")) Then
			AutoType = "NUT"
			ElseIf params.Contains("SD2") And (Not params.Contains("NLG")) Then
			AutoType = "WASHER"
			ElseIf params.Contains("SEWI") Then
			AutoType = "C SINK"
			ElseIf params.Contains("KOD") And (Not params.Contains("SEWI")) Then
			AutoType = "SOCKET SCREW"
			ElseIf params.Contains("FAWI") Then
			AutoType = "GRUB"
			ElseIf (Not params.Contains("B_L")) Then
			AutoType = "PLATE"
			Else
			AutoType = ""
			End If
		End Try
		'Set Shape Type
		Else
		oType = AutoType
		End If
		Case "PLATE"
		Case "F BAR"
		Case "CHS"
		Try
		Catch
		AutoName = ""
		End Try
		Case "SHS", "RHS"
		Try
		Else
		End If
		Catch
		AutoName = ""
		End Try
		Case "RD BAR"
		Try
		Catch
		AutoName = ""
		End Try
		Case "RSA"
		Try
		Catch
			Try
			AutoName = "RSA " & Parameter(oPart, "b") & " x " & Parameter(oPart, "b") & " x " & Parameter(oPart, "ParT")
			Catch
				AutoName = ""
			End Try
		End Try
		Case "PFC"
		Try
		Catch
		AutoName = ""
		End Try
		Case "UC", "UB"
		Try
		Else
		End If
		Catch
		AutoName = ""
		End Try
		Case "BOLT"
		Try
		AutoName = oClass & stand & " HEX BOLT"
		Catch
		AutoName = ""
		End Try
		Case "NUT"
		Try
		AutoName = oClass & stand & " HEX NUT"
		Catch
		AutoName = ""
		End Try
		Case "WASHER"
		Try
		AutoName = oClass & " FLAT WASHER, FORM A"
		Catch
		AutoName = ""
		End Try
		Case "C SINK"
		Try
		AutoName = oClass & stand & " COUNTERSINK SCREW"
		Catch
		AutoName = ""
		End Try
		Case "SOCKET SCREW"
		Try
		AutoName = oClass & stand & " SOCKET SCREW"
		Catch
		AutoName = ""
		End Try
		Case "GRUB"
		Try
		AutoName = oClass & stand & " GRUB SCREW"
		Catch
		AutoName = ""
		End Try
		Case Else
		AutoName = ""
		End Select
		Else
		End If
MechMachineMan
ProTip:
Code is generally much, much easier to write, edit and refactor if it is laid out for proper encapsulation, instead of all put under one function..
Seeing that many lines of code put into one function makes my head spin. Especially when trying to figure out what it actually does/how.
Ex:/// When setting autoname fails to set because it has issues finding the parameters, instead of putting the try/catch in EVERY case statement, rewrite it as a function that does the error checking and returns the proper results. Be mindful of whether you want to accomplish this via
1) A Sub (or occasionally a function) using a input/return variable by reference
2) A Sub using global variables
3) A function.
Did you find this reply helpful ? If so please use the 'Accept as Solution' or 'Like' button below.
Justin K
Inventor 2018.2.3, Build 227 | Excel 2013+ VBA
ERP/CAD Communication | Custom Scripting
Machine Design | Process Optimization
iLogic/Inventor API: Autodesk Online Help | API Shortcut In Google Chrome | iLogic API Documentation
Vb.Net/VBA Programming: MSDN | Stackoverflow | Excel Object Model
Inventor API/VBA/Vb.Net Learning Resources: Forum Thread
Sample Solutions:Debugging in iLogic ( and Batch PDF Export Sample ) | API HasSaveCopyAs Issues |
BOM Export & Column Reorder | Reorient Skewed Part | Add Internal Profile Dogbones |
Run iLogic From VBA | Batch File Renaming| Continuous Pick/Rename Objects
Local Help: %PUBLIC%\Documents\Autodesk\Inventor 2018\Local Help
Ideas: Dockable/Customizable Property Browser | Section Line API/Thread Feature in Assembly/PartsList API Static Cells | Fourth BOM Type
jmfowler1996
Haha.
Yeah, it's honestly a miracle that the code isn't in even worse format than it is. I was never taught to code. I just saw other people's iLogic rules and learnt bits and pieces from them.
Also, I didn't really make this rule for others to use. It was actually just for me. I shared it because it's incredibly handy for me and I know other people might benefit from it. I would like for people to be able to easily mould it to their needs, but I really don't have the experience coding. I find a method that works, and stick with it.
I'll definitely keep your tips in mind for future though.
MechMachineMan
Annnnnd here's what it looks like refactored into a slightly more logical layout.
A ton of redundancy and unused lines were also removed.
There might be some bugs to fix yet/some extra error checking to add, but at least it should be much, much easier to follow.
Sub Main()
    oDoc = ThisDoc.Document
    oDrawCurveSeg = ThisApplication.CommandManager.Pick(Inventor.SelectionFilterEnum.kDrawingCurveSegmentFilter, "Select a Drawing Curve")
'Input validation
	Try
		Exit Sub
	End Try
	Dim oSelectedModelDoc As Document
	Try
    	oSelectedModelDoc = oDrawCurve.ModelGeometry.Parent.ComponentDefinition.Document
	Catch
			MsgBox("No model assosciated with selected curve found!")
	End Try
'End of input validation
    AutoName = AutoDescriptionBasedonType(oSelectedModelDoc)
	oPart = System.IO.Path.GetFileName(oSelectedModelDoc.FullFileName)
'Provide final user input to verify name
	oNewDescription = InputBox("Description for '" & oPart & "':", "Description Editor", AutoName)
	Else
	End If
End Sub
Sub GetDocDims(oDoc As Document, ByRef Length As String, ByRef Width As String, ByRef Thickness As String)
	'Grab range box of each surface body and combine to get the max range box
	'Get the overall dims using the rangebox max/min points
	'Sort these overall dims from smallest to largest and assign as length width and thickness
	oCompDef = oDoc.ComponentDefinition
	Dim minp As point
	Dim maxp As point
	Dim oRB As Box
	Try
			Else
			End If
		Next
		minp = oRB.minPoint
		maxp = oRB.maxPoint
		Exit Sub
	End Try
	dp=0
	extents.add(X)
	extents.add(Y)
	extents.add(Z)
	extents.Sort()
	Width = extents(1)
	Length = extents(2)
End Sub
Sub GetClassAndStandFromProperty(oPN As String, ByRef oClass as String, ByRef stand As String)
		Try
			stockclass = Split(oPN, "-")
			End If
				If Not InStr(oPN, "UNC") = 0 Then
					stand = " UNC"
				End If
				If Not InStr(oPN, "UNF") = 0 Then
					stand = " UNF"
				End If
			Else
				stand = ""
			End If
		Catch
		End Try
End Sub
Function GetParamTypeFromList() As String
		Try
			params.Add(param)
		Catch
		End Try
	Next
		AutoType = "PFC"
		AutoType = "RHS"
		AutoType = "CHS"
		AutoType = "RD BAR"
		AutoType = "UC"
		AutoType = "RSA"
		AutoType = "F BAR"
		AutoType = "BOLT"
		AutoType = "NUT"
		AutoType = "WASHER"
		AutoType = "C SINK"
		AutoType = "GRUB"
		AutoType = "PLATE"
	Else
		AutoType = ""
	End If
	Return AutoType
End Function
Function AutoDescriptionBasedonType(oDoc As Document) As String
	'To Auto description, we need dims, classification, standard, and stock number values to check against.
	'We also need to establish a type (which may or may not already be in the part) to establish what we want
	'the Default description To be
'Value Prep
	Dim Length, Width, Thickness As String
	Call GetDocDims(oDoc, Length, Width, Thickness)
	Dim oClass, stand As String
	Dim oPN As String
	oPN = iProperties.Value(oPart, "Project", "Part Number")
	Call GetClassAndStandFromProperty(oPN, oClass, stand)
	Try
	Catch
	End Try
'Get Type
	Try
		oType = GetParamTypeFromList()
	End Try
	'Set Shape Type
	If oType = "" Then
	End If
	AutoName = ""
	Try
			Case "PLATE"
			Case "F BAR"
			Case "CHS"
			Case "SHS", "RHS"
				Else
				End If
			Case "RD BAR"
			Case "RSA"
				Try
				Catch
				End Try
			Case "PFC"
			Case "UC", "UB"
				Else
				End If
			Case "BOLT"
			Case "NUT"
			Case "WASHER"
			Case "C SINK"
			Case "SOCKET SCREW"
			Case "GRUB"
			Case Else
				AutoName = ""
		End Select
	Catch
		AutoName = ""
	End Try
	Return AutoName
End Function
Justin K
MechMachineMan
With how it was written, I definitely had difficulty in understanding why you would go through the trouble of making the whole param array only to check it against itself and apparently establish a type based off of that.
The confusing part is why you didn't just write a simple case/if structure to check the existence of parameters in a part and make a type based off of that.
ie;
Sub Main()
    If ParamsExist(oDoc, "G_L", "A_F") = True Then
          Type = "Plastic"
   Else if ParamsExist(oDoc, "b", "t", "k") = True Then
           Type = some custom type
   End if
End SUb
Function ParamsExist(oDoc, ByVal ParamArray paramstocheck As String()) As Boolean
       For each oParam in paramstocheck
           Try
                 oDoc.Parameters(oParam)
            Catch
                 'Accessing prop failed; it doesn't exist
                 Return False
                 Exit Sub
            End Try
       Next
       Return True
End Function
Justin K
jmfowler1996
Why would you torture yourself sorting my code? XD
Thanks, though. I'll have a thorough look at this hopefully tomorrow. I'm sure I can also learn a lot from seeing what you changed and why.
Regarding the param array, I didn't even know how to use functions as you showed. As I say, I only know what I've observed from other rules I've seen.
jmfowler1996
*There must be a better way than re-posting updates in full below all of the other versions. This is getting ridiculous.
Unfortunately, your code did not work.
I fixed the rule, and created a function to check if parameters exist as you suggested. It works great now and, thanks to your changes, even works for changing the description of standard content centre parts, which wasn't possible before.
Module mod1
Public oPart As String
End Module
Sub Main()
'Input validation
	Try
		'leave empty so that esc key cancels rule without pop-up.
		Exit Sub
	End Try
	Try
	Catch
	End Try
	Else
		iLogicVb.RunRule("Auto-Description")
	End If
End Sub
	Dim minp As point
	Dim maxp As point
	Dim oRB As Box
	Try
			Else
			End If
		Next
		minp = oRB.minPoint
		maxp = oRB.maxPoint
		Exit Sub
	End Try
	dp=0
	extents.add(X)
	extents.add(Y)
	extents.add(Z)
	extents.Sort()
	Width = extents(1)
	Length = extents(2)
End Sub
		Try
			End If
					stand = " UNC"
				End If
					stand = " UNF"
				End If
			Else
				stand = ""
			End If
		Catch
		End Try
End Sub
	If ParamsExist(1, "G_NG") Then
		AutoType = "PFC"
	ElseIf ParamsExist(1, "G_W", "G_T") And ParamsExist(0, "G_T1", "G_ER") Then
		AutoType = "RHS"
	ElseIf ParamsExist(1, "G_T") And ParamsExist(0, "G_W") Then
		AutoType = "CHS"
	ElseIf ParamsExist(1, "G_H") And ParamsExist(0, "G_T", "G_W") Then
		AutoType = "RD BAR"
	ElseIf ParamsExist(1, "G_T1") And ParamsExist(0, "G_NG") Then
		AutoType = "UC"
	ElseIf ParamsExist(1, "G_ER") Or ParamsExist(1, "b") Then
		AutoType = "RSA"
	ElseIf ParamsExist(1, "G_W") And ParamsExist(0, "G_T") Then
		AutoType = "F BAR"
	ElseIf ParamsExist(1, "NLG", "SW", "SD2") Then
		AutoType = "BOLT"
	ElseIf ParamsExist(1, "SW") And ParamsExist(0, "NLG") Then
		AutoType = "NUT"
	ElseIf ParamsExist(1, "SD2") And ParamsExist(0, "NLG") Then
		AutoType = "WASHER"
	ElseIf ParamsExist(1, "SEWI") Then
		AutoType = "C SINK"
	ElseIf ParamsExist(1, "KOD") And ParamsExist(0, "SEWI") Then
	ElseIf ParamsExist(1, "FAWI") Then
		AutoType = "GRUB"
	ElseIf ParamsExist(0, "B_L") Then
		AutoType = "PLATE"
	Else
		AutoType = ""
	End If
	Return AutoType
End Function
Function ParamsExist(checkType As Integer, ByVal ParamArray paramstocheck As String()) As Boolean
	For Each oParam in paramstocheck
		'MessageBox.Show("Checking for: " & oParam, "iLogic")
		Try
			testparamexists = Parameter(oPart, oParam)
			If checkType = 0 Then
				Return False
			End If
		Catch
			If checkType = 1 Then
				Return False
			End If
		End Try
	Next
	Return True
End Function
'Value Prep
	Dim oPN As String
	Try
	Catch
	End Try
'Get Type
	Try
	End Try
	'Set Shape Type
	If oType = "" Then
	End If
	AutoName = ""
	Try
			Case "PLATE"
			Case "F BAR"
			Case "CHS"
			Case "SHS", "RHS"
				Else
				End If
			Case "RD BAR"
			Case "RSA"
				Try
				Catch
				End Try
			Case "PFC"
			Case "UC", "UB"
				Else
				End If
			Case "BOLT"
			Case "NUT"
			Case "WASHER"
			Case "C SINK"
			Case "SOCKET SCREW"
				AutoName = oClass & stand & " SHCS"
			Case "GRUB"
			Case Else
				AutoName = ""
		End Select
	Catch
		AutoName = ""
	End Try
	Return AutoName
End Function
Curtis_Waguespack
@jmfowler1996 wrote:
... how to use functions ...
Hi jmfowler1996,
Just as an FYI for the future as well, have a look at this AU class:
http://au.autodesk.com/au-online/classes-on-demand/class-catalog/2013/product-design-suite/ma1936#ch...
I hope this helps.
Curtis
jmfowler1996
Thanks!
I didn't even know that type of thing existed.
I'll have a look into it.
Dear Jonathan,
Thank you for your Ilogic code. we used part templates for normal parts in that way we always have good dimensions which we can export to an idw. In skeleton models its not helpfull though. I was wondering though if there is a way to reset the value's ? when I adjust a length in my skeleton model and rerun the rule the old dimension value's will not change to accommodate the new value's
Do you know an idea to reset your rule?
Kind regards,
Mitchel Stottelaar
jmfowler1996
Hi.
Can you please attach an example part which the rule isn't working for? It will give me a better idea of what you are meaning, and I can have a look into why it isn't working.
Thanks.
Thank you for your quick reply!
Below you find the wetransfer link for the assembly.
https://we.tl/t-fGVjLFsjHm
Kind regards,
Mitchel Stottelaar
jmfowler1996
Hello again Mitchel.
Thank you for making the issue very clear in your drawing. It was very useful.
I will address the issues individually:
1:
issue: round bar is called out as plate.
Cause: the iLogic code recognises different types of part by checking a part's parameter names. The parameter names in standard round bar taken from the content centre are very different from the names of the parameters in your custom part.
Solution: instead of extruding round bar, use round bar directly from inventor's content centre. In your case, maybe create a frame sketch part with the sketch lines of the frame members (round bars), and insert it into the assembly. You can then use frame generator to create round bars from the content centre.
Alternative Solution: You could technically also create a list of parameters which are the same as those in a content centre round bar, and the code will then recognize it as such.
2/3:
issue: plates are called out with incorrect dimensions
cause: this happens when the part's User Coordinate System (UCS) is not aligned with the part.
Workaround: there currently isn't a good way around this. You could create parts from scratch for diagonally placed parts. If you need them to be linked to the master assembly, you could link the parameters to the original sketch.
Solution: I have an idea about how to create a better workaround for this, based on the user adding a custom user coordinate system and the rule recognising that the latest UCS is the one to be used. I will add it to my long list of things to do!
issue: when part dimensions are changed and the rule is re-run, the dimensions given by the rule are outdated.
my comments: I couldn't reproduce this issue. Please see the screencast below where I change the sketch and the rule runs with the correct updated dimensions.
Screencast will be displayed here after you click Post.
ee1abc63-2fe2-4eb7-a442-cb5cc3341721
If you mean that you want the sizes in the BoM to update without running the rule again, I will look into it, but I don't think it will be easy.
jmfowler1996
Okay, it looks like that screencast link didn't work.
The screencast is here:
https://knowledge.autodesk.com/community/screencast/ee1abc63-2fe2-4eb7-a442-cb5cc3341721
And I will try one last time to embed it in the comment...
