Announcements
Ilogic rule that allows for editing a ilogic table part in an assembly??
I have an assembly which is made from parts which are all illogic tables. I know how to use the iPart.ChangeRow so that I can switch between versions of the part but the issue is that I have the variable 'Length' that is not a set value. I want to be able to alter the length within a rule in the assembly.
I have tried:
Parameter("PIPE iLogic", "Length") = Offstand
However this comes up with the following error:
Catastrophic failure (Exception from HRESULT: 0x8000FFFF (E_UNEXPECTED))
Is there anyway of altering this parameter so that it alters all the versions of the part in the ilogic table???
Any help is much appreciated. I hope this makes sense.
mcgyvr
https://forums.autodesk.com/t5/inventor-forum/ilogic-ipart-custom-column-value-setting/td-p/2842680
Doing it a different way now which removes this issue. Anyone else can use this thread if they have a similar problem.
