iLogic Rule not running when a part is dragged
- Mute
- Permalink
- Report
Hi All,
I have an assembly and some iLogic code. However, I'm struggling to get the Rule to run when I drag a part around. In a nutshell, I drag the part and an angle changes. The code measures the angle and should then set the angle of another part elsewhere in the assembly.
Sub Main RuleParametersOutput() InventorVb.DocumentUpdate() Ang01 = Measure.Angle("BEAM - STR 06 - 10mm:1", "XZ Plane", "BEAM - STR 13 - 60mm:1" , "XZ Plane") 'Parameter("Ang02") = Ang01 d419 = Ang01 * 2 RuleParametersOutput() InventorVb.DocumentUpdate() End Sub
I'm completely new to iLogic, however, I have tried to diagnose the problem a bit. Under the Rule Options, the tickboxes for "Suppressed" and "Don't run automatically" are turned off. d419 is blue. Under Event Triggers, I have added to the Rule to:
Any Model Parameter Change
iProperty Change
Component Suppression Change
iPart or iAssembly Change Component.
After dragging the first part, if I run the rule manually, then the 2nd part updates correctly.
Link copied
