ilogic rule for placing the Vault-Revision table on a Inventor-drawing
MarkusGreifeneder3360
I need an ilogic rule that places the Vault-Revision-Table on the first page (or active page) of the opened Inventor-drawing.
The insert point should be related to the right/lower corner of the sheet and the insert Point can be modified in the ilogic rule (x/y)
Can someone help?
Thank you for your advice
Markus
Replies (17)
chandra.shekar.g
Autodesk Support
Autodesk Support
Hi @MarkusGreifeneder3360,
Try the following iLogic rule to insert / add Revision Table.
Dim oDrawingDoc As DrawingDocument
oDrawingDoc = ThisApplication.ActiveDocument
Dim oSheet As Sheet
oSheet = oDrawingDoc.ActiveSheet
Dim oTablePt As Point2d
oTablePt = ThisApplication.TransientGeometry.CreatePoint2d(2, 3)
Dim oRevTable As RevisionTable
oRevTable = oSheet.RevisionTables.Add(oTablePt)
Please feel free to contact if there is any doubt.
If solves problem, click on "Accept as solution" / give a "Kudo".
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Autodesk Developer Network
Thank you Chandra,
works nearly perfect for me!
Could you please expand the code with 2 issues:, to make it perfect:
- Position should be related to the right/lower edge of the sheet (actual left/lower)
- Check bevor placing, if there is a "Revision table" already existing, if YES don't set it again
Thanks in advance
Best regards
Markus
chandra.shekar.g
Autodesk Support
Autodesk Support
Changes made to iLogic rule as per the requirement. Check the same.
Dim oSheet As Sheet
oTablePt = ThisApplication.TransientGeometry.CreatePoint2d((oSheet.Width - 17), 3)
If oSheet.RevisionTables.Count = 0 Then
Else
    MessageBox.Show("Revision Table already exist", "Autodesk Inventor")
End If
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
RoyWickrama_RWEI
I used the code. with oTable  as shown below:
SyntaxEditor Code Snippet
oTablePt = ThisApplication.TransientGeometry.CreatePoint2d((oSheet.Width-7.75*2.54), 3.4375*2.54)
Horizontally, it is perfect. Vertically, revision table is as shown blow.
Could you help to place the revision block at BOTTOM-LEFT (or BOTTOM-RIGHT) corner.
b.graaf
I was looking for something like this.
But if I use the code, I get the "normal" revision table, not the Vault revision table. Or at least it starts with a Revision number of 1, while the Vault revision scheme starts with 0.
Is this a error in the code, or a setting in Inventor/Vault?
MairA_DUKA
Hello
With your code I will get a normal RevisionTable and not the Vault-RevisionTable.
I tried this code to get the correct RevisionTable:
ThisApplication.CommandManager.ControlDefinitions.Item("VaultRevisionBlock").Execute
Now in the drawing I must click to positionate the RevisionTable.
Is it possible to automate this so that the RevisionTable is inserted on a certain 2D-point?
YuhanZhang
Can you try if below iLogic code works there:
Sub Main()
	Dim oCls As New WindowsFunc(ThisApplication)
	oCls.PlaceRevTable
End Sub
Class WindowsFunc
        Private Declare Auto Function SetCursorPos Lib "user32" (ByVal x As Long, ByVal y As Long) As Long
        Private Declare Sub mouse_event Lib "user32"(ByVal dwFlags As Long, ByVal dx As Long, ByVal dy As Long, ByVal cButtons As Long, ByVal dwExtraInfo As Long)
	Private oApp   As Inventor.Application
	Const MOUSEEVENTF_LEFTDOWN = &H2 ' left button down
 	Const MOUSEEVENTF_LEFTUP = &H4 ' left button up
	Sub New(m_App As Inventor.Application)
		oApp = m_App
	End Sub
	Sub PlaceRevTable
	Dim x As Long = oApp.Left + oApp.Width / 2
	Dim y As Long = oApp.Top + oApp.Height / 2
	SetCursorPos(x, y)
    oApp.CommandManager.ControlDefinitions.Item("VaultRevisionBlock").Execute
   	mouse_event(MOUSEEVENTF_LEFTDOWN, 0, 0, 0, 0)
   	mouse_event(MOUSEEVENTF_LEFTUP, 0, 0, 0, 0)
End Sub
End Class
If this solves the problem please click ACCEPT SOLUTION so other people can find it easily.
Rocky Zhang
Inventor API PD
Manufacturing Solutions
MairA_DUKA
Hello
Your code not works.
I have to click with the mouse still on the right position.
YuhanZhang
Try below iLogic code:
Sub Main()
	oCls.PlaceRevTable
End Sub
Class WindowsFunc
		oApp = m_App
	End Sub
	Sub PlaceRevTable
		SetCursorPos(x, y)
		Dim i As Integer
		Do While i < 50
			If i = 0
		    	oApp.CommandManager.ControlDefinitions.Item("VaultRevisionBlock").Execute2(False)
			End If
		i = i +1
		Loop
	End Sub
End Class
Rocky Zhang
Inventor API PD
MairA_DUKA
Hello
This is not the solution that I am searching.
Your code will place the Vault-RevisionTable on the center of the screen.
I want place the RevisionTable on a certain X- and Y-Position on the Layout from the Inventor-Drawing.
Thanks for your helb, but I will positionate the RevisionTable manually.
tobias_wiesendanger
This should be possible if you placed it. After that you can search over your sheet by the name of it. Something like this:
Sub UpdateCustomTable()
Dim oDrawDoc As DrawingDocument
Set oDrawDoc = ThisApplication.ActiveDocument
Dim oSheet As Sheet
Set oSheet = oDrawDoc.ActiveSheet
Dim oTable As RevisionTable
Dim oTablePosition As Point2d
Set oTablePosition = ThisApplication.TransientGeometry.CreatePoint2d(0, 0)
For Each oTable In oSheet.RevisionTables
    If oTable.Title = "REVISION HISTORY" Then
        oTable.Position = oTablePosition
    End If
Next
End Sub
Im wondering if there isnt a better way than to use the direct command to place it. This feels like a bad workaround for not allowing any option inside of the normal revision table to choose what to place.
david.wartaJA24W
Double post
D.Warta
Van Halteren Technologies Boxtel B.V., Netherlands
david.wartaJA24W
Dear Rocky Zhang,
Your code does the trick for placing a vault revision table. However I would like to move the revision table after it is placed. Currently I use code given by tobias.wiesendanger.
If I try to run the to codes in sequence using
iLogicVb.RunExternalRule("Rule1")
iLogicVb.RunExternalRule("Rule2")
But it does not move the revision table. When I start the rules separately is does work? Any ideas to have one rule to sequence them both. Do I need to activate the sheet again after the placing of the revision table?
thanks in advance,
D.Warta
D.Warta
YuhanZhang
You can merge Tobias's code into my iLogic rule, like below:
Sub Main()
	oCls.PlaceRevTable
	' Move the revision table to proper position.
	UpdateCustomTablePosition(0,0)
End Sub
Sub UpdateCustomTablePosition(PosX As Double, PosY As Double )
oDrawDoc = ThisDoc.Document
Dim oSheet As Sheet
' Specify the position to move the revision table to.
oTablePosition = ThisApplication.TransientGeometry.CreatePoint2d(PosX, PosY)
    End If
Next
End Sub
Class WindowsFunc
		oApp = m_App
	End Sub
	Sub PlaceRevTable
		SetCursorPos(x, y)
		Dim i As Integer
		Do While i < 50
			If i = 0
			End If
		i = i +1
		Loop
	End Sub
End Class
Can you try it there to check if it works well?
Rocky Zhang
Inventor API PD
david.wartaJA24W
Thanks for responding. I tried it, but unfortunately it does not move the revision table. It does place the revison table but does not move it. If I run the script twice it will place another revision table and move the old one.
Btw.  I'm still using inventor 2020.
D.Warta
david.wartaJA24W
In inventor 2024 it is the same behavior
D.Warta
tmuel
I am able to get this to work using Inventor 2022 and 2024.
Use the code from this thread to place a revision table with the API options for a normal revision table.
https://forums.autodesk.com/t5/inventor-programming-ilogic/insert-revision-table-using-bottom-left-c...
Modify to use the DRAWING scope, instead of SHEET scope.
oRevTable = oSheet.RevisionTables.Add2(oTablePt, FALSE, True, True, "0", oRevTableStyle, )
If your Vault revision tables are configured properly, and you have revisions for this file in Vault, right click over the rev table and you should see the same option to "Populate Vault Data" that you see if you had manually placed a "Vault Revision Table".
Now change the state and cycle the revisions a few times, open the drawing and you will see it populates automatically. Now, manually place a "Vault Revision table" with the same style - you should see that they are identical.
I hope that helps someone else as much as the referenced post helped me.
Tim
