iLogic Rule for deploying an userdefined Multivalue Parameter to all parts of an assembly
stigler
stigler
Hello, good evening!
As I am a beginner in iLogic I have another question to you:
I have an iLogic rule for parts to create an userdefined Multivalue Parameter in the active part. I would like to use this rule in an assembly for all the parts referenced in the active assembly.
Dim oPartDoc As Document
oPartDoc = ThisDoc.Document
If oPartDoc.DocumentType = kPartDocumentObject Then
	Dim oPartCompDef As PartComponentDefinition
		oPartCompDef = oPartDoc.ComponentDefinition
Dim oParams As Parameters
		oParams=oPartCompDef.Parameters
		Dim oUserParams As UserParameters
		oUserParams=oParams.UserParameters
		Dim oAwesomeParameter As Parameter
		Try
			otester = oUserParams.Item("SI_Z1")
			Catch
oInsulationType = oUserParams.AddByValue("SI_Z1", " ", kTextUnits)
MultiValue.SetList("SI_Z1", "g", "kg", "l", "m2",  "m3",  "mm",  "PC",  "STK",  "t")
			End Try
Parameter.Param("SI_Z1").ExposedAsProperty = False
Parameter.Param("SI_Z1").IsKey = False
I have tried a lot of different ideas to create a loop but it didn't work!
It would be great if you could give me a solution for this problem.
Thank You very much for help in previous
Curtis_Waguespack
Hi @stigler
Welcome to the world of iLogic. I think this example will work for you.
I hope this helps.
Curtis
Sub Main
	Dim oADoc As AssemblyDocument = ThisApplication.ActiveDocument
	Dim oOccs As ComponentOccurrences = oADoc.ComponentDefinition.Occurrences
	Call TraverseAssembly(oOccs)
	InventorVb.DocumentUpdate()
End Sub
Function TraverseAssembly(oOccs As ComponentOccurrences)
	Dim oOcc As ComponentOccurrence
	For Each oOcc In oOccs
		oDoc = oOcc.Definition.Document
		If oOcc.DefinitionDocumentType = DocumentTypeEnum.kAssemblyDocumentObject Then
			Call TraverseAssembly(oOcc.SubOccurrences)
		Else 'parts
			Call SetList(oOcc)
	Next
End Function
Sub SetList(oOcc As ComponentOccurrence)
	Dim oPartDoc As PartDocument
	oPartDoc = oOcc.Definition.Document
	oParams = oPartDoc.ComponentDefinition.Parameters
	oUserParams = oParams.UserParameters
	oParamName = "SI_Z1"
	sDefault = "g"
	Try
		oParam = oUserParams.Item(oParamName)
	Catch
		oParam = oUserParams.AddByValue(oParamName, sDefault, kTextUnits)
	End Try
	MultiValue.SetListInComponent(oOcc.Name, oParamName, sDefault, "kg", "l", "m2", "m3", "mm", "PC", "STK", "t")
End Sub
stigler
Hello Curtis_Waguespack thank you for your help!
It's running perfectly!
Greetings from Austria
Stigler
