ILogic Rule for Automated labels in a drawing
I'm making a sheet metal template and I was wondering if there is already a ilogic rule out there that automatically fills in the 'Label' as the actual 'Part Number' when I bring the part into the .idw drawing? In addition, I would need the label to have 'FLAT-PATTERN' underneath if I choose to bring in a flat-pattern view. The label format should look like:
<PART NUMBER>
SCALE <SCALE>
FLAT-PATTERN
I would appreciate any direction or help!
Thanks!
MechMachineMan
You do not need iLogic for this.
You need to modify the relevant style in your template file.
Styles Editor > Standard (select the active standard) > "View Preferences" Tab.
Once you get there, you can click the pencil beside the Display Box to change the view label for the selected view type.
There is likely much more documentation out there between autodesk university, the generic autodesk documentation, and the google machine.
Did you find this reply helpful ? If so please use the 'Accept as Solution' or 'Like' button below.
Justin K
Inventor 2018.2.3, Build 227 | Excel 2013+ VBA
ERP/CAD Communication | Custom Scripting
Machine Design | Process Optimization
iLogic/Inventor API: Autodesk Online Help | API Shortcut In Google Chrome | iLogic API Documentation
Vb.Net/VBA Programming: MSDN | Stackoverflow | Excel Object Model
Inventor API/VBA/Vb.Net Learning Resources: Forum Thread
Sample Solutions:Debugging in iLogic ( and Batch PDF Export Sample ) | API HasSaveCopyAs Issues |
BOM Export & Column Reorder | Reorient Skewed Part | Add Internal Profile Dogbones |
Run iLogic From VBA | Batch File Renaming| Continuous Pick/Rename Objects
Local Help: %PUBLIC%\Documents\Autodesk\Inventor 2018\Local Help
Ideas: Dockable/Customizable Property Browser | Section Line API/Thread Feature in Assembly/PartsList API Static Cells | Fourth BOM Type
