Announcements
iLogic_Rule_Batch_Tool in Autodesk app store Error
ramesh_parjapatDBLNB
Observer
Observer
Observer
  1. I am using this tool to copy ilogic parameters into multiple parts in one go and it's working fine (India) but our team in USA having below error while running the same.
  2. We ran this tool in multiple users in India and its working fine.
Any idea how to solve this ?
bradeneuropeArthur
could you share the code and te error?
Arthur Knoors
Autodesk Affiliations:
Programming Examples:Drawing List!|Toggle Drawing Sheet!|Workplane Resize!|Drawing View Locker!|Multi Sheet to Mono Sheet!|Drawing Weld Symbols!|Drawing View Label Align!|Open From Balloon!|Model State Lock!
Posts and Ideas:Dimension Component!|Partlist Export!|Derive I-properties!|Vault Prompts Via API!|Vault Handbook/Manual!|Drawing Toggle Sheets!|Vault Defer Update!
Observer
Observer
This is the error..!!
Observer
Observer
This is ther error..!!
I am not able to see what the error is with this message only.
What version of the code are you using?
Could you share the code?
Arthur Knoors
