iLogic - Rename hole description in a Hole Tabele
6 REPLIES 6
571 Views, 6 Replies
Hi everybody, I have one question
I want to edit column "HOLE" with Ilogic
I need code like this:
If Row = "Ø3x2" in DESCRIPTION column Then write Row = "A1" in HOLE column
I found this thread: https://forums.autodesk.com/t5/inventor-forum/rename-holes-in-a-hole-tabele/td-p/5420234
but there is only the numbering of the rows there.
I cant read Descriprion property with use this function: HoleTableRow.ReferencedHole () As Object
Here are my holes:
A1 - Ø3x2
B1 - Ø5x12
B2 - Ø5x32
B3 - Ø5 - through
B4 - Ø5x20
B5 - Ø5x34
C1 - Ø8x12
C2 - Ø8x25
C3 - Ø8 - through
D1 - Ø15x12
D2 - Ø15x18
D3 - Ø15x20
E1 - Ø35x10
6 REPLIES 6
rossano_praderi
with reference with the thread which you refer in your post, replace ""oHoleRow.HoleTag.Text" with "oHoleRow.Item(ColumnIndexBase1).Text" to get access on every column of holetable.
In your case "ColumnIndexBase1" = 2 and for "Quantity" = 3
See this link as reference.
Bregs
Rossano Praderi
If my post answers your question, please click the "Accept as Solution"
button. This helps everyone find answers more quickly!
in reply to: rossano_praderi
Thank you very much for your help!
This code works well with the Column3 (Quantity)
But I need change Column1 if Column2 ="text" in my case "Ø3x2"
Now iLogic return me error: "Conversion from string "Ø3x2" to type 'Double' is not valid."
oDrwDoc = ThisApplication.ActiveDocument
Dim oSheet As Sheet
Dim i As Integer
oSheet = oDrwDoc.ActiveSheet
Dim oHoleTables As HoleTables
oHoleTables = oSheet.HoleTables
Dim oTable As HoleTable
Dim oTableRow As HoleTableRow
Dim oTableRows As HoleTableRows
For Each oTable In oHoleTables
    For i = 1 To oTable.HoleTableRows.Count
		If Len(oTable.HoleTableRows.Item(i).Item(2).Text) = "Ø3x2" Then
               oTable.HoleTableRows.Item(i).Item(1).FormattedText = "A1"
        End If
    Next
Next
Can anyone help me, please.
Thank you in advance
rossano_praderi
if you would like to change only the text value as a simple text the use "Text".
Use "FormattedText" when you would keep/assign the format.
oTable.HoleTableRows.Item(i).Item(1).Text = "A1"
Bregs
Rossano Praderi
Thanks, is better:
Dim oSheet As Sheet
Dim i As Integer
		If oTable.HoleTableRows.Item(i).Item(2).FormattedText = "Ø3x2" Then
        End If
    Next
Next
but it still does not work with my Column2 - in my HoleTable it's written like this:
Ø<HDIA>x<HDPT>
I can't read: "<HDIA>", "<HDPT>" and sign "Ø" to use If functions.
I got it:
Dim oSheet As Sheet
Dim i As Integer
'Dim oPR As HoleProperty
'Dim A11 As String = oPR.HolePropertyID(77581)
'A11 = "3"
		If oTable.HoleTableRows.Item(i).Item(2).Text = ("n"&"3"&"x"&"2") Then
        End If
    Next
Next
Thank you very much Rossano Praderi
rossano_praderi
You are welcome.
And if you like to make your code short...
    For Each oTableRow in oTable.HoleTableRows
	    If oTableRow.Item(2).Text = ("n"&"3"&"x"&"2") Then
               oTableRow.Item(1).FormattedText = "A1"
        End If
    Next
Next
Bregs
Rossano Praderi
