iLogic read Weldment material name
steeninvent_dk
steeninvent_dk
Hello
I need to read the Assembly Weldment material name with iLogic, anyone know how I can achieve this?
Regards Lars
MechMachineMan
Weldment document iProperties
Dim oDoc As Document
oDoc = ThisApplication.ActiveDocument
oMatl = oDoc.PropertySets.Item("Design Tracking Properties").Item("Material").Value
Did you find this reply helpful ? If so please use the 'Accept as Solution' or 'Like' button below.
Justin K
Inventor 2018.2.3, Build 227 | Excel 2013+ VBA
ERP/CAD Communication | Custom Scripting
Machine Design | Process Optimization
iLogic/Inventor API: Autodesk Online Help | API Shortcut In Google Chrome | iLogic API Documentation
Vb.Net/VBA Programming: MSDN | Stackoverflow | Excel Object Model
Inventor API/VBA/Vb.Net Learning Resources: Forum Thread
Sample Solutions:Debugging in iLogic ( and Batch PDF Export Sample ) | API HasSaveCopyAs Issues |
BOM Export & Column Reorder | Reorient Skewed Part | Add Internal Profile Dogbones |
Run iLogic From VBA | Batch File Renaming| Continuous Pick/Rename Objects
Local Help: %PUBLIC%\Documents\Autodesk\Inventor 2018\Local Help
Ideas: Dockable/Customizable Property Browser | Section Line API/Thread Feature in Assembly/PartsList API Static Cells | Fourth BOM Type
steeninvent_dk
Thankyou, but this don't read weldment material definition but regular document material?
Curtis_Waguespack
Hi steen,
I think this should be what you're looking for.
I hope this helps.
Curtis
DTP_PropertySet = ThisDoc.Document.PropertySets.Item("Design Tracking Properties")
oWeldMatl = DTP_PropertySet.Item("Weld Material").Value
MessageBox.Show(oWeldMatl, "iLogic")
Or this using @MechMachineMan 's example:
oMatl = oDoc.PropertySets.Item("Design Tracking Properties").Item("Weld Material").Value
MessageBox.Show(oMatl, "iLogic")
steeninvent_dk
THANKYOU
It works :slightly_smiling_face:
