iLogic "Parameter box"
Cosmin_V
Cosmin_V
Hello
I have an iLogic tool on which I have create a lot of "User Parameters". In some situation some of them are "Off" and noting else can be selected instead of "Off".
Can I do some how, this Parameters which ar "Off" to be hide from the "Parameter box" instead of have 4 on "Off"
Is not there a rule whit which I can turn Off the Key?
philip1009
Here's a sample rule that will toggle the Parameter Key box of "Inlet" based on the text value:
colUserParams = ThisDoc.Document.ComponentDefinition.Parameters.UserParameters
objParamInlet = colUserParams.Item("Inlet")
If objParamInlet.Value = "Off" Then
	objParamInlet.IsKey = False
Else
	objParamInlet.IsKey = True
After putting in the rule, go to Manage > iLogic > Event Triggers and set the rule under Any Model Parameter Change.  As the name implies, every time something changes in the parameter table that rule will be run automatically.
P.S. Any questions related to iLogic, VBA, or Add-Ins are better suited for the Inventor Customization forum.
