iLogic program - Exporting .RVT file
urban.ostirZ44XW
urban.ostirZ44XW
can someone help me with writing an iLogic program that can export one .RVT document with all parts and subassembly of an assembly. Because if I export .RVT file with Inventor export wizard I get a file in witch I can reach only one level lower that the whole assembly is. I am attaching a photo of assembly exported into Revit file with just one level of subassembly.
On that photo we can see the problem I have presented. Model marked with blue color have in Inventor also subassemblies and individual components, which in this case are exported as one.
Looking forward to a replay.
Goran.JutrisaR5QUS
do you maybe have solution to this?
tnx
DVNK4SZN
same question.. Ilgic to export to .RVT
THX
Curtis_Waguespack
Hi @DVNK4SZN , welcome to the forum.
Here is an iLogic version based off of the VBA example included in Inventor's API help files.
Hope that helps, Curtis
Dim oDoc As AssemblyDocument
oDoc = ThisApplication.ActiveDocument
'Actiate the Master model state if the active model state is substitute
If oDoc.ComponentDefinition.ModelStates.ActiveModelState.ModelStateType = ModelStateTypeEnum.kSubstituteModelStateType Then
	oDoc.ComponentDefinition.ModelStates.Item(1).Activate
End If
Dim oRevitExportDef As RevitExportDefinition
oRevitExportDef = oDoc.ComponentDefinition.RevitExports.CreateDefinition
oRevitExportDef.Location = "C:\Temp"
oRevitExportDef.FileName = "MyRevitExport.rvt"
oRevitExportDef.Structure = RevitExportStructureTypeEnum.kEachTopLevelComponentStructure
oRevitExportDef.EnableUpdating = True
' Create RevitExport.
Dim oRevitExport As RevitExport
oRevitExport = oDoc.ComponentDefinition.RevitExports.Add(oRevitExportDef)
, i
How to find the API help:
Curtis_Waguespack
To the original question the only options are the same we have via the interface within Inventor.
DVNK4SZN
Great! Thanks!
is it also possible to update an already created Revit export?
