iLogic - Open File From Vault
Is it possible to open a file from the Vault using iLogic?  I want to batch process a large group of files, but the examples I am finding all show how to do it based on grabbing a file from the local workspace and I need to get the latest file from the Vault.
Using Vault Basic 2015 now, shortly upgrading to Vault Workspace (not sure if that affects anything with this).  Specifically I am trying to tweak this script to search for a list of files from the Vault and loop through them:
http://www.mastergraphics.com/wordpress/2014/batch-processing-with-ilogic/
Replies (12)
Richard.MM
I solved a similar problem and found that using iLogic can not access to the Vault. You must use .net.
Jef_E
@Richard.MM Hi, could you post your solution in .net? I'm also interested in this. Would be great to see a example.
Please kudo if this post was helpfull
Please accept as solution if your problem was solved
Inventor 2014 SP2
Richard.MM
Here is the code that download drawing from the vault and open it.
But you'll have to modify it for his own use.
VB.net:
Imports Autodesk.DataManagement.Client.Framework.Vault
Imports Autodesk.Connectivity.WebServicesTools
Imports VDF = Autodesk.DataManagement.Client.Framework
Imports ACW = Autodesk.Connectivity.WebServices
Imports System.Collections
Imports System.Windows.Forms
Public Class Otevr_zVault
    Dim fileIters As System.Collections.Generic.ICollection(Of VDF.Vault.Currency.Entities.FileIteration)
    Public Shared kontrola As String
    Public Sub stahni_vykr()
        Dim results1 As VDF.Vault.Results.LogInResult = VDF.Vault.Library.ConnectionManager.LogIn("xxx", "xxxx", "Administrator", "", VDF.Vault.Currency.Connections.AuthenticationFlags.WindowsAuthentication, Nothing)
        If Not results1.Success Then
            MsgBox("Error1")
        End If
        Dim connection As VDF.Vault.Currency.Connections.Connection = Nothing
        connection = results1.Connection
        Dim m_inventorApp As Inventor.Application = Nothing
        ' get running Inventor
        Try
            m_inventorApp = System.Runtime.InteropServices.Marshal.GetActiveObject("Inventor.Application")
        Catch ex As Exception
            MsgBox("Error2")
        End Try
        Try
            If m_inventorApp Is Nothing Then
                MsgBox("Error3")
                Return
            End If
        Catch
        End Try
        m_inventorApp.Visible = True
        Dim oDoc As Inventor.Document
        oDoc = m_inventorApp.ActiveDocument
        Dim fullfilename1 As String = oDoc.FullFileName
        Dim vykr As String
        If Not fullfilename1 = Nothing Then
            If oDoc.DisplayName.EndsWith(".ipt") Or oDoc.DisplayName.EndsWith(".iam") Then
                vykr = Microsoft.VisualBasic.Left(oDoc.DisplayName, InStrRev(oDoc.DisplayName, ".")) & "idw"
            ElseIf oDoc.DisplayName.EndsWith(".idw") Then
                vykr = oDoc.DisplayName
            Else
                vykr = oDoc.DisplayName & ".idw"
            End If
        Else
            MessageBox.Show("Error4")
            Return
        End If
        Dim oFolder3 As String = Microsoft.VisualBasic.Left(fullfilename1, InStrRev(fullfilename1, "\") - 1)
        Dim oFolder2 As String = Microsoft.VisualBasic.Left(oFolder3, InStrRev(oFolder3, "\"))
        If fullfilename1 = Nothing Then
            MsgBox("Error5")
            Return
        End If
        Dim fullfilename As String = oFolder2 & "Drawings\" & vykr
        Try
            Dim oFileIteration As VDF.Vault.Currency.Entities.FileIteration = Nothing
            Try
                'convert local path string to vault format
                Dim VaultPath As String = fullfilename
                If VaultPath.Contains("D:\Vault_Working\") Then
                    VaultPath = VaultPath.Replace("D:\Vault_Working\", "$/")
                ElseIf VaultPath.Contains("E:\Vault_Working\") Then
                    VaultPath = VaultPath.Replace("E:\Vault_Working\", "$/")
                Else
                    MsgBox("Error6 " + VaultPath)
                    Return
                End If
                VaultPath = VaultPath.Replace("\", "/")
                Dim VaultPaths() As String = New String() {VaultPath}
                Dim DocService As ACW.DocumentService
                DocService = connection.WebServiceManager.DocumentService
                Dim files As ACW.File() = Nothing
                Try
                    files = DocService.FindLatestFilesByPaths(VaultPaths)
                Catch
                End Try
                Dim file As ACW.File
                file = files(0)
                oFileIteration = New VDF.Vault.Currency.Entities.FileIteration(connection, file)
                MsgBox("Error7")
            End Try
            If oFileIteration IsNot Nothing Then
                'get settings
                Dim oSettings As VDF.Vault.Settings.AcquireFilesSettings = New VDF.Vault.Settings.AcquireFilesSettings(connection)
                oSettings.DefaultAcquisitionOption = VDF.Vault.Settings.AcquireFilesSettings.AcquisitionOption.Download 'Or VDF.Vault.Settings.AcquireFilesSettings.AcquisitionOption.Checkout
                oSettings.AddEntityToAcquire(oFileIteration)
                kontrola = "NE"
                connection.FileManager.AcquireFiles(oSettings)
            End If
            Dim Rodice As New Rodice
            Call Rodice.GetWhereUsed()
            Return
        Finally
            VDF.Vault.Library.ConnectionManager.LogOut(connection)
        End Try
        m_inventorApp.Documents.Open(fullfilename)
        kontrola = Nothing
    End Sub
End Class
I get error-
Type 'Rodice' is not defined
Richard.MM
Hello
These two lines are not necessary there
Simply delete them.
maxim.teleguz
Did you ever Get Whereused to work?
Richard.MM
yes
maxim.teleguz
are you able to post any code that you optimized to work for you?
I have been trying so hard to get it to work for us and we can get it to work but not consistently and it requires a lot of set up.
Richard.MM
I am sending the code we are using and it works.
MsgBox outputs are written in Czech language.
 Public Sub GetWhereUsed(m_inventorApp_rr As Inventor.Application)
        m_inventorApp = m_inventorApp_rr
        If m_inventorApp.ActiveDocument.DocumentType = Inventor.DocumentTypeEnum.kDrawingDocumentObject Then
            MessageBox.Show("Zdarec, máš otevřený výkres, akce bude přerušena", "Nespi!", MessageBoxButtons.OK, MessageBoxIcon.Error)
            Exit Sub
        End If
        Dim hledam As String = System.IO.Path.GetFileNameWithoutExtension(oDoc.FullFileName) + System.IO.Path.GetExtension(oDoc.FullFileName)
        Dim results As VDF.Vault.Results.LogInResult = VDF.Vault.Library.ConnectionManager.LogIn("xxxxx", "yyyyy", "zzzzz", "wwwww",
        Nothing)
        If Not results.Success Then
            MsgBox("Připojení k Vaultu se nezdařilo")
        End If
          connection = results.Connection
        Dim Defss As PropDef() = connection.WebServiceManager.PropertyService.GetPropertyDefinitionsByEntityClassId("ITEM")
        Dim Prop As PropDef = Nothing
        For Each def As PropDef In Defss
            If def.DispName = "Revision" Then
                Prop = def
            End If
        Next def
        Dim searchCondition As SrchCond = New SrchCond()
        searchCondition.PropDefId = Prop.Id
        defs = connection.WebServiceManager.PropertyService.FindPropertyDefinitionsBySystemNames("FILE", {"ClientFileName"})
        srchCond.PropDefId = defs(0).Id
        srchCond.PropTyp = PropertySearchType.SingleProperty
        srchCond.SrchRule = SearchRuleType.Must
        srchCond.SrchOper = 3
        srchCond.SrchTxt = hledam
        SrcConds(0) = srchCond
        Try
            files = connection.WebServiceManager.DocumentService.FindFilesBySearchConditions(SrcConds,
        Nothing,
        Nothing,
        True,
        True,
        bookmark,
        searchStatus)
        Catch
            MsgBox("Nemohu ziskat soubor z Vaultu")
        End Try
        Dim assocArray2 As FileAssocArray() = Nothing
        For Each chci In files
            If chci.Name = hledam Then
                assocArray2 = connection.WebServiceManager.DocumentService.GetLatestFileAssociationsByMasterIds(New Long() {chci.MasterId},
        FileAssociationTypeEnum.All,
        True,
        FileAssociationTypeEnum.None,
        True,
        True,
        True,
        True)
            End If
        Next
        If assocArray2(0).FileAssocs Is Nothing Then
            MessageBox.Show("Nemohu najít žádný výkres, zřejmě to budš muset udělat ručně!")
            Return
        End If
        Dim vykresy(assocArray2(0).FileAssocs.Count) As String
        If Not assocArray2 Is Nothing Then
             For i = 0 To assocArray2(0).FileAssocs.Count - 1
                If assocArray2(0).FileAssocs(i).ParFile.Name.EndsWith("idw") Then
                    If Not assocArray2(0).FileAssocs(i).ParFile.Name Is Nothing Then
                        vykresy(i) = assocArray2(0).FileAssocs(i).ParFile.Name
                    End If
                End If
            Next
        Else
            MessageBox.Show("Nemohu najít žádný výkres.")
            Exit Sub
        End If
        Dim arr As New ArrayList
        For i As Integer = 0 To vykresy.Length - 1
            If Not arr.Contains(vykresy.GetValue(i)) Then
                arr.Add(vykresy.GetValue(i))
            End If
        Next
        vykresy = arr.ToArray(GetType(String))
        Me.Show()
        Dim prvni As Integer = 0
        For Each sr In vykresy
            prvni = prvni + 1
            If Not sr Is Nothing Then
                If prvni = 1 Then
                    Me.CheckedListBox1.Items.Add(sr, True)
                Else
                    Me.CheckedListBox1.Items.Add(sr, False)
                End If
            End If
        Next
        TextBox1.AppendText(System.IO.Path.GetFileNameWithoutExtension(oDoc.FullFileName) + ".idw")
    End Sub
JBerns
Would this VB.NET code work with Vault Basic?
We are currently on 2019 versions, but upgrading soon.
CAD Administrator
Using Inventor 2022
Autodesk Certified Instructor
Autodesk Inventor 2020 Certified Professional
Autodesk AutoCAD 2017 Certified Professional
Richard.MM
I don't know, it was originally made for Vault professional 2017. Now we have switched to Professional 2022 and after recompiling it into new libraries it still works.
rcolon9E4ZX
@Richard.MM ,
Do you have a solution for VBA? This is what I have available for connecting with INV2022. Is there a shift for Autodesk using VB.NET, and is VBA going to get discontinued?
Kind regards,
Rafael
