ilogic Open Assembly with All Components Suppressed
johnster100
johnster100
I'm looking for some code to open a document with all components suppressed. I had a look at OpenWithOptions in the help file but this did not have an open for this.
can someone help?
thanks,
John
WCrihfield
Hi @johnster100.  You can use the ThisApplicaiton.Documents.OpenWithOptions method, which will allow you to specify that 'all suppressed' LOD (or ModelState).  But of course you would have to have created that LOD or ModelState ahead of time, otherwise it will not be an available option.  It would be nice if there was already a pre-existing LOD or ModelState like that, but unfortunately there was not.
Wesley Crihfield
(Not an Autodesk Employee)
WCrihfield
A couple of other settings that may help in cases like this are the:
ApplicationOptions > Assembly tab > Defer update
and the
ApplicationOptions > Assembly tab > Enable Express mode worflows - check the checkbox,
then set 'File Open Options' below that to 'Open Express when referenced unique files exeeds'
and set the number very low, like 4.
Disable the option named "Enable relationship redundancy analysis", on that same page.
All these settings can be accessed by code too, so you could temporarily set them this way ahead of opening assemblies, then set them back the way you normally want them, after the assembly has been opened.
Wesley Crihfield
WCrihfield
Another idea would be to create/use an external iLogic rule, as a batch preparation utility, that you can run during 'off hours', that will process an entire directory of assembly files at a time.  Opening each one, record its originally active LOD, then attempt to create the needed 'all components suppressed' LOD (or ModelState), then suppress all of the components, then set the LOD back to original, then save the assembly.  That way, you will have the needed LOD's in place for future use.  I'm pretty sure I have seen others here on the forums use that technique before too, so there may already be code like that here somewhere.  It does not see like it would be too difficult to create something like that, but it would have to be thoroughly debugged, and fool proof, so it can run unattended.
Wesley Crihfield
Curtis_Waguespack
Hi @johnster100,
Here is a quick attempt at some of what @WCrihfield suggests.
I haven't tested it much, but did run it on a few small assemblies I had on hand.
This rule will:
  • allow you to select an assembly file
  • open it invisibly in express mode
  • create a Model State called "All Components Suppressed"
  • then suppress each component
  • then open the file visible in the "All Components Suppressed" model state
I hope this helps.
Curtis
Sub Main
	sMSName = "All Components Suppressed"
	Dim oFileName As String = Select_File()
	If oFileName Is Nothing Then Exit Sub
	Dim oDoc As AssemblyDocument
	oDoc = OpenInvisible_Express(oFileName)
	Dim oMSExists As Boolean = CreateModelState(oDoc, sMSName)
	If oMSExists = False Then
		MsgBox("Could find or create " & sMSName)
		Exit Sub
	End If
	Call OpenAllSuppressed(oFileName, sMSName)
End Sub
Sub OpenAllSuppressed(oFileName As String, sMSName As String)
	Dim oOptions As NameValueMap
	oOptions = ThisApplication.TransientObjects.CreateNameValueMap
	Call oOptions.Add("ModelState", sMSName)
	oDoc = ThisApplication.Documents.OpenWithOptions(oFileName, oOptions, True)
End Sub
Function OpenInvisible_Express(oFileName As String)
	Call oOptions.Add("ExpressModeBehavior", "OpenExpress")
	oDoc = ThisApplication.Documents.OpenWithOptions(oFileName, oOptions, False)
	Return oDoc
End Function
Function CreateModelState(oDoc As AssemblyDocument, sMSName As String)
	Dim oAsmCompDef As AssemblyComponentDefinition
	oAsmCompDef = oDoc.ComponentDefinition
	Dim oModelState As ModelState
	'create ModelState in the top level
	Try : oModelState = oAsmCompDef.ModelStates.Add(sMSName) : Catch : End Try
	Try
		oAsmCompDef.ModelStates.Item(sMSName).Activate
		oMSExists = True
	Catch
		oMSExists = False
		GoTo EndFunction
	End Try
	oAsmCompDef.ModelStates.MemberEditScope = MemberEditScopeEnum.kEditActiveMember
	Dim oOcc As ComponentOccurrence
	For Each oOcc In oDoc.ComponentDefinition.Occurrences
		oOcc.Suppress(True)
	Next
	EndFunction :
	Return oMSExists
End Function
Function Select_File()
	Dim oFileDlg As Inventor.FileDialog = Nothing
	InventorVb.Application.CreateFileDialog(oFileDlg)
	oFileDlg.InitialDirectory = ThisApplication.FileLocations.Workspace
	oFileDlg.CancelError = True
	oFileDlg.MultiSelectEnabled = False
	oFileDlg.ShowQuickLaunch = False
	oFileDlg.Filter = "Assembly Files (*.iam)|*.iam"
	oFileDlg.DialogTitle = "Select a file."
	On Error Resume Next
	oFileDlg.ShowOpen()
	If Err.Number <> 0 Then
		Exit Function
	ElseIf oFileDlg.FileName <> "" Then
		Return oFileDlg.FileName
	End If
End Function
