Ilogic Multi value list
JorisSteurs1246
JorisSteurs1246
I try to get my part names in a MultiValue list,
I got stuck in my last line of teh code  where I try to get an array into the parameter.
Code as follows:
SyntaxEditor Code Snippet
    'check this file is an assembly
        Dim doc As Document = ThisApplication.ActiveDocument
        If doc.DocumentType = kPartDocumentObject Then
            MessageBox.Show("This rule can only be run in an assembly file!", "ERROR")
            Return
    ' Get the active assembly.
    Dim oAsmDoc As AssemblyDocument
        oAsmDoc = ThisApplication.ActiveDocument
    ' Get the assembly component definition.
    Dim oAsmDef As AssemblyComponentDefinition
        oAsmDef = oAsmDoc.ComponentDefinition
    ' Get all of the leaf occurrences of the assembly.
    Dim oLeafOccs As ComponentOccurrencesEnumerator
        oLeafOccs = oAsmDef.Occurrences.AllLeafOccurrences
    Dim NameList As New ArrayList()
    ' Iterate through the occurrences and collect the name.
    Dim oOcc As ComponentOccurrence
    For Each oOcc In oLeafOccs
    NameList.add(oOcc.Name )
    Next
    oMyParameter=ThisApplication.ActiveDocument.ComponentDefinition.Parameters.UserParameters
'Setting an userParameter as text parameter
    Try
            otester = oMyParameter.Item("AwesomeParameter")
    Catch
   oInsulationType=oMyParameter.AddByValue("AwesomeParameter", "", kTextUnits)
End Try
    MultiValue.List("AwesomeParameter") = NameList
Curtis_Waguespack
Hi JorisSteurs1246 ,
Here is an example that should show one way to do this.
I hope this helps.
Curtis
    Return
Next
Try
Catch
	oInsulationType=oMyParameter.AddByValue("AwesomeParameter", "", UnitsTypeEnum.kTextUnits)
	'make parameter a multivalue list parameter
	MultiValue.SetList("AwesomeParameter", "ListValue1", "ListValue2", "ListValue3")
End Try
'set list parameter to use array list
'get user input
oSelection = InputListBox("Select one:", MultiValue.List("AwesomeParameter"), _
Parameter("AwesomeParameter"),  "iLogic", "List of Component Occurrences:")
'catch null selection
If oSelection = "" Then
	Return 'exit rule
Else
	'set parameter value
	Parameter("AwesomeParameter") = oSelection
'provide user feedback
MessageBox.Show("You selected: " & oSelection, "iLogic")
JorisSteurs1246
Hi Curtis,
Thank you so much, this works very well Smiley Happy  I could now also see where I made my mistake.
Thanks for the listbox extension you provided, this will come in handy as well. One problem I found with the listbox is that I can't drag the width of the box.
This would mean that in most of my designs the names will be only half readable. Is there, by any change, a way I can control the width of the box?
Thanks again
Joris
Curtis_Waguespack
Hi JorisSteurs1246,
Unfortunately, there is not a way to resize the input list box. But you could use an iLogic form and add the list parameter to it.
http://help.autodesk.com/view/INVNTOR/2015/ENU/?guid=GUID-6BE90A26-3CEB-481C-873C-4D85853375C6
https://knowledge.autodesk.com/support/inventor-products/learn-explore/caas/CloudHelp/cloudhelp/2016...
I hope this helps.
Curtis
JorisSteurs1246
Yes I'm working with forms a lot, but I was afraid that the multi value list parameter wouldn't update, so tested it but this works fine.
Thanks for pointing to that.
Joris
ricksmithYGQR7
I'm Trying to do something similar to this for drafting support. I need a script that will allow a user to select from a list of values and pull from an if statement the corresponding file to apply a title block from the selected file to a target drawing file.
I am working with an existing script that was working at one time when we had only 1 drawing template.
We now want to maintain 4 templates for parts, sheet metal, assemblies and weldments. Each with styles and tolerances applied to the title block. So, I think I need to add a multi-value param and test it against a selected value.
But I haven't done this stuff in some time so any help would be appreciated.
'replace title block with 1 of 4 title blocks dependent on template type part, assembly, sheetmental or weldment
Sub Main()
'Check if the document is drawing
	If ThisApplication.ActiveDocument Is Nothing Or ThisApplication.ActiveDocumentType <> kDrawingDocumentObject Then
	    MsgBox ("Please run this from a drawing.")
	    Exit Sub
    Dim oDrawingDoc As Inventor.DrawingDocument: oDrawingDoc = ThisApplication.ActiveDocument
    Dim SheetNumber As Integer
'        'Transfer Prompted Text
			iLogicVb.RunExternalRule("Xfer Prompted Text")
		'Add Custom iProps
			iLogicVb.RunExternalRule("Add Custom iProps")
    'Clear out the old Titleblocks
    For SheetNumber = 1 To oDrawingDoc.Sheets.Count
        oDrawingDoc.Sheets(SheetNumber).Activate
		If Not oDrawingDoc.ActiveSheet.TitleBlock Is Nothing Then
        oDrawingDoc.ActiveSheet.TitleBlock.Delete
    Next SheetNumber
		DeleteTitleBlocks(oDrawingDoc) 'CALLING SUBROUTINE
		'create list to select from and call the title block selected to place in target drawing.
		'MultiValue.SetList("TemplateType", ), As String, ParamArray args As Object()(Part, Assembly, Sheet_Metal, Weldment)))
		'test selection and apply file title block below.
		If "TemplateType" =Part Then
		ThisDrawing.ResourceFileName = "C:\_Vault\CAD Stds\Inventor\Templates\part.idw"
	Else If "TemplateType" = Assembly Then
		ThisDrawing.ResourceFileName = "C:\_Vault\CAD Stds\Inventor\Templates\assembly.idw"
	Else If "TemplateType" = Sheet_Metal Then
		ThisDrawing.ResourceFileName = "C:\_Vault\CAD Stds\Inventor\Templates\sheetmetal.idw"
	Else If "TemplateType" = Weldment Then
		ThisDrawing.ResourceFileName = "C:\_Vault\CAD Stds\Inventor\Templates\weldment.idw"
        ThisDrawing.KeepExtraResources = False
				For Each oSheet In oDrawingDoc.Sheets
				oSheet.Activate
					ActiveSheet.TitleBlock = "MVPTLBLOCK"
					ActiveSheet.Border = "MVP BORDER"
				Next
		'Change Line Weight
			Dim oDrawDoc As DrawingDocument
			oDrawDoc = ThisApplication.ActiveDocument
			For Each oLayer In oDrawDoc.StylesManager.Layers
			oLayer.LineWeight = 0.007 / 0.393701
			Next
        iLogicVb.UpdateWhenDone = True
        ThisApplication.ActiveDocument.Sheets(1).Activate()
        ThisApplication.ActiveView.Fit
		oModelBP = oDrawDoc.BrowserPanes.Item("DlHierarchy")
			For Each oNode In oModelBP.TopNode.BrowserNodes
				oNode.Expanded = False
			Next
End Sub
'Subroutine
Sub DeleteTitleBlocks(oActiveDoc As Inventor.DrawingDocument)
'Iterate through the collection deleting any titleblocks that are not referenced by the drawing object
Dim oTitle As TitleBlockDefinition
    For Each oTitle In oActiveDoc.TitleBlockDefinitions
        If oTitle.IsReferenced = False Then
        oTitle.Delete
    Next
End Sub
ricksmithYGQR7
Looking at the accepted solutions provided some ideas, but I think that because they are targeted for part or assembly environment, I have to change how they are collecting information.
