Ilogic move drawingdimensions
I am trying to move some drawingdimensions with ilogic, but it is not working.
with the help of the VBA tool i could find the coordinates of the dimensionlines, but it looks they are read-only.
Why are these dimensions read only, and can't be moved with ilogic?
for my code i have a simple drawing that has 4 dimensions on it.
Dim osheet As Sheet = ThisApplication.ActiveDocument.activesheet
Dim oview As DrawingView = osheet.DrawingViews(1)
Dim dimension As GeneralDimension
For Each dimension In osheet.DrawingDimensions
	Trace.WriteLine(dimension.ModelValue)
	If dimension.DimensionLine.direction.y = 1 Then
		Trace.WriteLine("Direction y=1")
		dimension.DimensionLine.MidPoint.X = oview.Center.X - (oview.Width * 0.5) - 0.6
	ElseIf dimension.DimensionLine.direction.y = -1 Then
		Trace.WriteLine("Direction y=-1")
		dimension.DimensionLine.MidPoint.X = oview.Center.X + (oview.Width * 0.5) + 0.6
	ElseIf dimension.DimensionLine.direction.x = 1 Then
		Trace.WriteLine("Direction x=1")
		dimension.DimensionLine.MidPoint.Y = oview.Center.Y - (oview.Height * 0.5) -0.6
	ElseIf dimension.DimensionLine.direction.x = -1 Then
		Trace.WriteLine("Direction x=-1")
		dimension.DimensionLine.MidPoint.Y = oview.Center.Y + (oview.Height * 0.5) + 0.6
	End If
Next
Trace.WriteLine("rule done")
i also tried to create a point2D and then move the MidPoint of the dimensionline to the point. but that also doesn't work
I am able to read out all the values of the dimensionline, so ilogic can find the correct properties.
Trace.WriteLine(dimension.DimensionLine.MidPoint.X & " " & dimension.DimensionLine.MidPoint.Y)
Kind regards,
Geert
clutsa
You're on the right track with the point2D but try moving the Text.Origin
dimension.Text.Origin = ThisServer.TransientGeometry.CreatePoint2D((oview.Center.X - (oview.Width * 0.5) - 0.6), dimension.Text.Origin.Y)
If I've helped you, please help me by supporting this idea.
Mass Override for Each Model State
Custom Glyph Icon for iMates
JelteDeJong
i see that clutsa just answerd your question befor i could post my code. i will post it anyway because it's a bit more extensive but comes down to the same.
        Dim doc As DrawingDocument = ThisApplication.ActiveDocument
        Dim oSheet As Sheet = doc.ActiveSheet
        'Dim dimension As GeneralDimension
        Dim oTg = ThisApplication.TransientGeometry
        For Each dimension As DrawingDimension In oSheet.DrawingDimensions
            Dim midPointText As Point2d = dimension.Text.Origin
            Dim midPointView = oview.Center
            Dim textHeight = 0.5
            Dim newX As Double
            Dim newY As Double
            Dim deltaX As Double = (oview.Width * 0.5) + 0.6
            Dim deltaY As Double = (oview.Height * 0.5) + 0.6
            If (midPointText.X > midPointView.X + oview.Width / 2) Then
                newX = midPointView.X + deltaX
                newY = midPointView.Y
            End If
            If (midPointText.X < midPointView.X - oview.Width / 2) Then
                newX = midPointView.X - deltaX - textHeight
            End If
            If (midPointText.Y > midPointView.Y + oview.Height / 2) Then
                newY = midPointView.Y + deltaY + textHeight
            End If
            If (midPointText.Y < midPointView.Y - oview.Height / 2) Then
                newY = midPointView.Y - deltaY
            End If
            Dim newMidPoint As Point2d = oTg.CreatePoint2d(newX, newY)
            dimension.Text.Origin = newMidPoint
        Next
Jelte de Jong
Blog: hjalte.nl - github.com
Thanks!! that worked great!!
but as clutsa did in the code, when y or x don't change they should be:
newY = dimension.Text.Origin.Y
or
newX = dimension.Text.Origin.X
then they move like they should.
thanks again.
vvvxxvvv333
a good rule of thumb is to have one dimension per side. And how should it be changed if there were more dimensions? On the left are three dimensional lines.
