iLogic Measure Inside Assembly
felix.cortes5K3Y2
felix.cortes5K3Y2
Hi Forum!
I am trying to measure from a component occurrence inside a sub assembly to the XZ work plane on the main assembly. The component occurrence gets selected by the user and has a work surface called "Face0". My goal is to measure from "Face0" of the selected occurrence to "XZ Plane".
Here's the code I've written:
	Dim oAsm As AssemblyDocument = ThisApplication.ActiveDocument
	Dim oAsmComp As AssemblyComponentDefinition = oAsm.ComponentDefinition
	Dim Splice As ComponentOccurrence
	Splice = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kAssemblyLeafOccurrenceFilter, "Select a splice plate")
	Dim Height As Double
	'Height = Measure.MinimumDistance(Splice, "Face0", "", "GROUND PLANE")
	Height = Measure.MinimumDistance(Splice, "Face0", oAsm, "GROUND PLANE")
This code currently gets an error not sure why. I was wondering if someone has worked on a code similar to this before.
The occurrence part is inside "Assembly1" and I am running the code from "Assembly2" as shown in the snippet below
Felix
JhoelForshav
Hi @felix.cortes5K3Y2
It's strange, but it seems there is no way to use Measure.MinimumDistance to measure the distance between an entity in a component and an entity in the top level assembly...
Then we'll have to use more advanced API functionality:
Sub Main
	Dim oUM As UnitsOfMeasure = oAsm.UnitsOfMeasure
	'Create a proxy for Face0 (The face in the context of the assembly)
	Dim oFace0 As Object
	Splice.CreateGeometryProxy(GetNamedEntity(Splice.Definition.Document, "Face0"), oFace0)
	'Get the XZ Plane of the assembly
	Dim oXZplane As WorkPlane = oAsmComp.WorkPlanes.Item("XZ Plane")
	'Measure distance
	Dim Height As Double = ThisApplication.MeasureTools.GetMinimumDistance(oFace0, oXZplane)
	'Convert distance from database units to default units of the document
	Height = oUM.ConvertUnits(Height, UnitsTypeEnum.kDatabaseLengthUnits, oUM.LengthUnits)
	'Return the value in a messagebox just to control that it's right
	MsgBox(Height)
End Sub
Public Function GetNamedEntity(doc As Inventor.Document, name As String) As Object
    Dim attribMgr As AttributeManager = doc.AttributeManager
    Dim objsFound As ObjectCollection
    objsFound = attribMgr.FindObjects("iLogicEntityNameSet", "iLogicEntityName", name)
    If objsFound.Count > 0 Then
        Return(objsFound.Item(1))
    Else
        Return(Nothing)
    End If
End Function
felix.cortes5K3Y2
Hi Jhoel,
This worked great! Is there any way to measure the Y distance? That's the dimension most crucial for me and I thought that the minimum distance would give me that dimension. Either way thank you for helping me out!
Felix
JhoelForshav
I believe something like this should give you the Y-value:
Sub Main
	'Measure distance
	Dim oNV As NameValueMap
	Call ThisApplication.MeasureTools.GetMinimumDistance(oFace0, oXZplane, , , oNV)
	Dim oVector As Vector = oNV.Item("ClosestPointOne").VectorTo(oNV.Item("ClosestPointTwo"))
	Height = oUM.ConvertUnits(Abs(oVector.Y), UnitsTypeEnum.kDatabaseLengthUnits, oUM.LengthUnits)
	MsgBox(Height)
End Sub
    Else
        Return(Nothing)
    End If
End Function
Russell.BrownVEZMW
Has anyone since found a way to use Measure.MinimumDistance to measure the distance between an entity in a component and an entity in the top level assembly? Measure.MinimumDistance works really well for what I'm writing, since you don't need to define what type of geometry/feature you are measuring between, i.e. you just have to specify their names.
Kay_Rethmeier
Hi Russel,
maybe a trick can help you:
Place a dummy component (as reference part, no impact for BOM and weight, can be an empty file without geometry) at the origin to your assy and measure to this!?! Maybe not the best , but will be totally easy without that bunch of coding. :beaming_face_with_smiling_eyes:
Cheers
Kay (Principal CAD-Consultant)
