iLogic issues DXF export after computer rebuild
Howdy
I got a virus thhe week before last called the teslacrypt virus.  I had to rebuild my computer from backup and I'm now  having problems with iLogic scripts.
The PDF and STEP still works, but the DXF throws an error
Error in rule: Generate DXF, in document: 009-0016.idw
The parameter is incorrect. (Exception from HRESULT: 0x80070057 (E_INVALIDARG))
"More Info"
System.ArgumentException: The parameter is incorrect. (Exception from HRESULT: 0x80070057 (E_INVALIDARG))
at System.RuntimeType.ForwardCallToInvokeMember(String memberName, BindingFlags flags, Object target, Int32[] aWrapperTypes, MessageData& msgData)
at Inventor.TranslatorAddIn.SaveCopyAs(Object SourceObject, TranslationContext Context, NameValueMap Options, DataMedium TargetData)
at LmiRuleScript.Main()
at Autodesk.iLogic.Exec.AppDomExec.ExecRuleInAssembly(Assembly assem)
at iLogic.RuleEvalContainer.ExecRuleEval(String execRule)
My vault and vault files were apparently untouched by the virus, and so I used the iLogic Browser to add the PDF, STEP, and drawing DXF back in.
Of course, I didn't need to do that for the files to run these scripts that already had them added as a "before save" action.  But regardless, none of them work.
I did not write them, I simply downloadedd them from our vault and added them in.  One of the draftsman here found them on the internet.  I had great luck running them before the virus.  This is a brand new installation of windows and Inventor 2014 sp2.
Any ideas?  Board would not let me upload iLogicVB so rename the file from iam
TB
Bump. Thanks
Pretty Please?
There's no risk here folks, the virus encrypted my files and I was forced to start fresh from backup, and everything has been scanned a dozen times with Bitdefender and many others....
I don't know where we got these scripts, they have been working fine for at least a year and now since the rebuild it's not working, where theoretically everything should be the same.
Thanks.
TB
Well, I guess the software must be "self-healing".
I did a manual DXF output, and chose to save the .ini file with presets, and now the iLogic script is working again.
I didn't do anything but that.
If you have the problem described above, try doing a manual "Save As" dxf and save a configuration file of your settings, then try to run the script again.
