iLogic Insert Text Parameter into a Text Field
fce
fce
Hello there,
I´m trying to create an iLogic rule to replace the author of old drawings (which is written manually) with the current author of the drawing, but I would like to keep the author as a text parameter <Author> and not as simple text.
I managed to changed but only as simple text. I´m sure that I´m just missing the correct function.
Bellow the current code. I would really appreciate some quick help.
' Replace "FCE" , "MPO", "RMO", "BAR", "DGO", "HJD" with Author
'Is the active document a drawing document?
If ThisApplication.ActiveDocument.DocumentType = kDrawingDocumentObject Then Dim objDoc As Document objDoc = ThisApplication.ActiveDocument Dim objDrawDoc As DrawingDocument objDrawDoc = objDoc Dim colTitleBlkDefs As TitleBlockDefinitions colTitleBlkDefs = objDrawDoc.TitleBlockDefinitions Dim objTitleBlkDef As TitleBlockDefinition For Each objTitleBlkDef In colTitleBlkDefs ' If we are here, we have the title block of interest. ' Get the title block sketch and set it active Dim objDrwSketch As DrawingSketch Call objTitleBlkDef.Edit(objDrwSketch) Dim colTextBoxes As TextBoxes colTextBoxes = objDrwSketch.TextBoxes Dim objTextBox As TextBox For Each objTextBox In colTextBoxes Select Case objTextBox.Text Case "FCE", "MPO", "RMO", "BAR", "DGO", "HJD" If objTextBox.Text <> UserFullName ' I´M STRUGGLING WITH THIS NEXT LINE objTextBox.FormattedText = "<StyleOverride FontSize='0,25'>" & iProperties.Value("Summary", "Author") & "</StyleOverride>" ' Exit For Else done=1 Exit For End If End Select If done = 1 Exit For End If Next objTextBox Call objTitleBlkDef.ExitEdit(True) Next objTitleBlkDef End If
Replies (7)
johnsonshiue
Hi! I am not an iLogic expert. But, I think you might approach the issue in a wrong way. Where did the following values originally come from? Where they from the Author iProperty? If yes, you should change the iProperty value and everything will update accordingly.
Many thanks!
Software Test Engineer
fce
The values "FCE", "MPO", "RMO", "BAR", "DGO", "HJD" were manually written.
I would like to eliminate this old method.
fce
Do you have any idea how to achieve it?
JhoelForshav
Hi @fce
How about this? :slightly_smiling_face:
	objDrawDoc = objDoc
				objTextBox.FormattedText = "<Property Document='drawing' PropertySet='Inventor Summary Information' Property='Author' FormatID='' PropertyID=''>AUTHOR</Property>"
'					Exit For
				Else
					done=1
					Exit For
				End If
				End Select
				If done = 1
					Exit For
				End If
			Next objTextBox
		Next objTitleBlkDef
End If
fce
Hello JhoelForshav,
thanks a lot, it works.
How would you add the style override like in the previous version of the rule?
objTextBox.FormattedText = "<StyleOverride FontSize='0,25'>" & UserFullName & "</StyleOverride>"
 Greetings,
Francisco
JhoelForshav
Glad it works @fce
Try this to include the style override :slightly_smiling_face:
objTextBox.FormattedText = "<StyleOverride FontSize='0,25'> <Property Document='drawing' PropertySet='Inventor Summary Information' Property='Author' FormatID='' PropertyID=''>AUTHOR</Property> </StyleOverride>"
fce
Nice! That´s awesome, Thanks.
