iLogic How to Separate Values in a Text File?
I am using iLogic to read a .txt file, although the file does not have comma separated values. How would I get iLogic to separate each word and number into separate variables?
I've spent a lot of time researching how to do this, but I haven't found much information. This is my first time using iLogic, so I am not familiar with a lot of its functions and capabilities. I've attached a view of the .txt file as well as my code.
Thank you.
Sergio.D.Suárez
Your code is fine, what happens is that you need to have well defined the separators of the strings, otherwise the task becomes more difficult. regards
oFile = "C:\Users\Sergio\Desktop\Example.txt"
oRead = System.IO.File.OpenText(oFile)
'read the file
EntireFile = oRead.ReadToEnd()
oRead.Close()
'create aray from text info
'splitting at that comma
oSplit = Split(EntireFile, " ")
For Each wrd In oSplit
MessageBox.Show("Word Index #" & i & " = " & oSplit(i))
i += 1
Next
Please accept as solution and give likes if applicable.
I am attaching my Upwork profile for specific queries.
Sergio Daniel Suarez
Mechanical Designer
| Upwork Profile | LinkedIn
Thank you for your help. I was able to get the message box to show up.
Is there a way to access those individual numbers and save them as custom iProperties?
Thanks.
johnsonshiue
Hi! I believe it should be doable. You just need to give the Custom iProperty a name and assign a value.
Many thanks!
Software Test Engineer
