Hi @dimamazutaMMJ32
here is a quick example.
I hope this helps.
Curtis
oSheets = ThisApplication.ActiveDocument.Sheets
' Loop thru the sheets
For Each oSheet In oSheets
oName = oSheet.name
'get only left of the :
oSplit = Split(oName, ":")
oName = oSplit(0)
'get only left of the (
oSplit = Split(oName, "(")
oName = oSplit(0)
'get only left of the )
oSplit = Split(oName, ")")
oName = oSplit(0).Trim
If oSheet.size = 9993 Then
oSize = " (A0)"
ElseIf oSheet.size = 9994 Then
oSize = " (A1)"
ElseIf oSheet.size = 9995 Then
oSize = " (A2)"
ElseIf oSheet.size = 9996 Then
oSize = " (A3)"
ElseIf oSheet.size = 9997 Then
oSize = " (A4)"
Else
oSize = ""
End If
oSheet.Name = oName & oSize
Next
Just for reference:
DrawingSheetSizeEnum Enumerator
Description
Drawing Sheet Sizes supported by Inventor.
Methods
| k12x18InDrawingSheetSize |
9999 |
12 in x 18 in (typically for architectural drawings). |
| k18x24InDrawingSheetSize |
10000 |
18 in x 24 in (typically for architectural drawings). |
| k24x36InDrawingSheetSize |
10001 |
24 in x 36 in (typically for architectural drawings). |
| k30x42InDrawingSheetSize |
10003 |
30 in x 42 in (typically for architectural drawings). |
| k36x48InDrawingSheetSize |
10002 |
36 in x 48 in (typically for architectural drawings). |
| k9x12InDrawingSheetSize |
9998 |
9 in x 12 in (typically for architectural drawings). Default page orientation is Portrait. |
| kA0DrawingSheetSize |
9993 |
A0 size (typically for metric units). |
| kA1DrawingSheetSize |
9994 |
A1 size (typically for metric units). |
| kA2DrawingSheetSize |
9995 |
A2 size (typically for metric units). |
| kA3DrawingSheetSize |
9996 |
A3 size (typically for metric units). |
| kA4DrawingSheetSize |
9997 |
A4 size (typically for metric units). |
| kADrawingSheetSize |
9987 |
A size (typically for inch units). |
| kBDrawingSheetSize |
9988 |
B size (typically for inch units). |
| kCDrawingSheetSize |
9989 |
C size (typically for inch units). |
| kCustomDrawingSheetSize |
9986 |
Custom size. Does (may) not fit one of the standard sizes. |
| kDDrawingSheetSize |
9990 |
D size (typically for inch units). |
| kDefaultDrawingSheetSize |
9985 |
Specifies the default setting. The more strongly typed value is the one returned in a query. |
| kEDrawingSheetSize |
9991 |
E size (typically for inch units). |
| kFDrawingSheetSize |
9992 |
F size (typically for inch units). |
