ilogic help
ilogic help
Josh_Metalogy
ilogic help
Josh_Metalogy
I have a bit of iLogic code that works on flat patterns and I need some help adding a new function to it. On the bend note if there is a bend radius of 11/16 I need it to give me a field where I can say, "See forming guide." The full text should read, "<DIR> <ANGL> R <RAD> SEE FORMING GUIDE." Below is the rule I would like to add this functionality to. Thank you!
doc = ThisDoc.Document
For Each oSheet In doc.Sheets
  For Each oView In oSheet.DrawingViews
    If oView.IsFlatPatternView Then
	oView.ShowLabel = True 'Turn on view label
 'oFSize = .1 'font size, units unknown
                ViewLabel = oView.Name
			'clear current view label
				oView.Label.FormattedText = ""
                oModelName = _
                oView.ReferencedDocumentDescriptor.ReferencedDocument.DisplayName
                Try
			oFSize = .1*2.54
            oMaterial = "<StyleOverride Underline='False'><Property Document='model' PropertySet='Design Tracking Properties' Property='Material' FormatID='{32853F0F-3444-11D1-9E93-0060B03C1CA6}' PropertyID='29'>DESCRIPTION</Property></StyleOverride>"
			oGauge = iProperties.Value(oModelName, "Custom", "ShtThk")
			oLength = iProperties.Value(oModelName, "Custom", "FlatLength")
			oWidth = iProperties.Value(oModelName, "Custom", "FlatWidth")
			oMaterial = iProperties.Value(oModelName, "Custom", "Material")
			'oName = iProperties.Value("Project", "Part Number") 'Only got the .idw file name
			oName = iProperties.Value(oModelName, "Custom", "FileName")
            'add the the iProperty to the current view label, with a dash separator
                oView.Label.FormattedText = "<StyleOverride FontSize='" & oFSize & "'>" & oMaterial & " - "& oGauge & vbCrLf & oLength & " x " & oWidth & vbCrLf & oName & "</StyleOverride>"
            'oOldLabel = oView.Label.Text
			'oView.Label.FormattedText = "<StyleOverride FontSize='" & oFSize & "'>" & oOldLabel & "</StyleOverride>"
			Catch
            'do nothing if error
                End Try
	If Not oView.IsFlatPatternView Then
	'	MsgBox("Not a Flat Pattern")
                'capture the current view label
		'		oView.Label.FormattedText = "insert here"
                oModelName = _
               Try
            o_iProp = iProperties.Value(oModelName, "Project", "Part Number")
               ' oView.Name = o_iProp
				oView.Label.FormattedText = o_iProp
            Catch
                End Try
  Next
Next
CA_Wald
Can you check if this rule works?
        oView.ShowLabel = True ' Turn on view label
        oView.Label.FormattedText = "" ' Clear current view label
        oModelName = oView.ReferencedDocumentDescriptor.ReferencedDocument.DisplayName
        Try
            oFSize = 0.1 * 2.54 ' font size in cm
            ' Get the model document
            Dim oModelDoc As PartDocument
            oModelDoc = oView.ReferencedDocumentDescriptor.ReferencedDocument
            ' Get flat pattern definition
            Dim oCompDef As SheetMetalComponentDefinition
            oCompDef = oModelDoc.ComponentDefinition
            ' Ensure flat pattern exists
            Dim oFlat As FlatPattern
            If oCompDef.HasFlatPattern Then
                oFlat = oCompDef.FlatPattern
            Else
                oCompDef.Unfold() ' <-- FIXED: Call method
            ' Check if any bend radius = 11/16"
            Dim showFormingGuide As Boolean = False
            For Each oBend In oFlat.BendResults
                If Math.Round(oBend.Radius, 4) = 0.6875 Then
                    showFormingGuide = True
                    Exit For
            Next
            ' Construct view label
            Dim labelText As String
            labelText = oMaterial & " - " & oGauge & vbCrLf & oLength & " x " & oWidth & vbCrLf & oName
            If showFormingGuide Then
                labelText = labelText & vbCrLf & "<DIR> <ANGL> R <RAD> SEE FORMING GUIDE"
            oView.Label.FormattedText = "<StyleOverride FontSize='" & oFSize & "'>" & labelText & "</StyleOverride>"
        Catch
            ' Do nothing on error
        End Try
    Else
        ' Not a flat pattern view
        Try
        Catch
        End Try
  Next
Next
Josh_Metalogy
Thank you for taking this on Wald. When I run this rule it will turn on the view label in flat patterns but the label is empty. Is it possible to put the forming guide note on the bend note that is 11/16 radius rather than in the view label? I ran it on a file that has the 11/16 radius.
