Ilogic >> Delete Sketched Symbol
joris.engelbertink
Message 1 of 8
joris.engelbertink
Can someone help me out with some iLogic to delete a sketched symbol from a drawing by its name?
I'm quite a beginner with this, so I might be overlooking something..
This is the code is have:
Dim oDrawDoc As DrawingDocument= ThisApplication.ActiveDocument
Dim oSketchedSymbolDef As SketchedSymbolDefinition
If oDrawDoc.oSketchedSymbolDef.Item = "Sketched Symbol Name" Then
oSketchedSymbolDef.Delete
Else
Thanks!
Replies (7)
Message 2 of 8
Curtis_Waguespack
Hi @joris.engelbertink,
Something like this should work to delete a symbol from the sheet. If you are wanting to delete the symbol from the drawing, you will need to go through each sheet and delete any instance of the symbol, and delete the symbol definition. If that is what you are after, post back and someone can likely provide an example.
'Define the drawing document
oDrawDoc = ThisDoc.Document
'Iterate through each symbol in the active sheet
For Each oSymbol In oDrawDoc.ActiveSheet.SketchedSymbols
	'look for the symbol by name
	If oSymbol.Name = "Sketched Symbol Name" Then
		oSymbol.Delete
Next
I hope this helps.
Curtis
Message 3 of 8
Nice, Curtis! I was always under the impression the delete method wouldn't work if the symbol def was referenced. I learned something new. Can I go home now? 🙂
Message 4 of 8
I guess it's all the difference between an instance and the actual object definition.
Message 5 of 8
SPALANIAPPANTN47S
In case, if the drawing contains multiple sheets , how to modify the program ?
Message 6 of 8
Mike_Y2
This loops through all sheets in the active drawing document. Note replace the name "test" to the name of your sketch symbol...
'Check this is a drawing document...
If Not TypeOf ThisDoc.Document Is DrawingDocument Then
	MessageBox.Show("This rule will only run on a drawing", _
	"Realm", MessageBoxButtons.OK, MessageBoxIcon.Information)
	'Exit sub if not a drawing document
	Exit Sub
Dim oDrawDoc As DrawingDocument = ThisApplication.ActiveDocument
'Loop through sheets
For Each oSheet In oDrawDoc.Sheets
	'Loop through each symbol
	For Each oSymbol In oSheet.SketchedSymbols
		If oSymbol.Name = "test" Then
			oSymbol.Delete
	Next
Next
Message 7 of 8
Mike_Y2
@SPALANIAPPANTN47S  see above
Message 8 of 8
Luke.NashWU9MY
Is there a way to modify this to go through and change all sheets and all open drawings?
