Ilogic Get the appearnce from the part to the drawing
204Е10
204Е10
Hi everyone,
I've tried to find the code for get the appearance of a part from the drawing and I don't want to use parameters the code would be something like the one shown below:
modelName = IO.Path.GetFileName(ThisDrawing.ModelDocument.FullFileName)
MessageBox.Show(iProperties.PartColor (modelName), "Title")
but unfortunately it doesn't work, someone can to help me with it?
Cheers
Sergio.D.Suárez
Hi, try the following code. I think it should work for you.
doc = ThisDrawing.ModelDocument
MessageBox.Show(doc.ActiveAppearance.displayname)
 I hope this helps with your problem. regards
Please accept as solution and give likes if applicable.
I am attaching my Upwork profile for specific queries.
Sergio Daniel Suarez
Mechanical Designer
| Upwork Profile | LinkedIn
I think he wanted the part appearance, not the document/display appearance.
204Е10
Thanks that is perfect.
