iLogic get partnumbers of certain parts, create a running list in assembly iprop
01:23 PM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hello Guys,
i have a certain assembly with 4-5 Parts and i want to fill the PartNumber of the Assembly with a running list of the ipts Part Numbers (Part1, Part2, Part3). Separated with commas or semicolon.
And how can i define Part 1 with a certain filename form, i.e.
If docFile.PropertySets.Item("Design Tracking Properties").Item("Part Number").Value = "*-*-*" Then
Part1 = docFile.PropertySets.Item("Design...
My Code so far, i hope you can help me out
SyntaxEditor Code Snippet
Dim openDoc As AssemblyDocument openDoc = ThisApplication.ActiveDocument Dim customPropSet As PropertySet Dim Parts As DocumentsEnumerator Parts = openDoc.AllReferencedDocuments Dim Part As Document Dim NameList As New ArrayList 'Iterate through the occurrences And collect the name. For Each docFile In openDoc.AllReferencedDocuments oPartNumber = (docFile.PropertySets.Item("Design Tracking Properties").Item("Part Number").Value) NameList.add(oPartNumber) Next If openDoc.DocumentType = 12291 Then For Each docFile In openDoc.AllReferencedDocuments If docFile.DocumentType = 12291 Then Try If Left(System.IO.Path.GetFileNameWithoutExtension(docFile.FullFileName),7) = "Schraub" Then docFile.PropertySets.Item("Design Tracking Properties").Item("Part Number").Value = NameList Else End If Catch End Try End If Next Else End If
