iLogic general notes in one text box multiple text heights
09:29 PM
I've been trying to figure out how to take the standard ilogic script for "add a general note" in the inventor help section and modify it so it will produce all the text in one text box as well as different height text for the title. Is this possible?
Script i'm trying to modify below:
Public Sub SheetTextAdd()
' Set a reference to the drawing document.
' This assumes a drawing document is active.
Dim oDrawDoc As DrawingDocument
Set oDrawDoc = ThisApplication.ActiveDocument
' Set a reference to the active sheet.
Dim oActiveSheet As Sheet
Set oActiveSheet = oDrawDoc.ActiveSheet
' Set a reference to the GeneralNotes object
Dim oGeneralNotes As GeneralNotes
Set oGeneralNotes = oActiveSheet.DrawingNotes.GeneralNotes
Dim oTG As TransientGeometry
Set oTG = ThisApplication.TransientGeometry
' Create text with simple string as input. Since this doesn't use
' any text overrides, it will default to the active text style.
Dim sText As String
sText = "Drawing Notes"
Dim oGeneralNote As GeneralNote
Set oGeneralNote = oGeneralNotes.AddFitted(oTG.CreatePoint2d(3, 18), sText)
' Create text using various overrides.
sText = "Notice: All holes larger than 0.500 n are to be lubricated."
Set oGeneralNote = oGeneralNotes.AddFitted(oTG.CreatePoint2d(3, 16), sText)
' Create a set of notes that are numbered and aligned along the left.
Dim dYCoord As Double
dYCoord = 14
Dim dYOffset As Double
Dim oStyle As TextStyle
Set oStyle = oGeneralNotes.Item(1).TextStyle
dYOffset = oStyle.FontSize * 1.5
' Simple single line text.
Set oGeneralNote = oGeneralNotes.AddFitted(oTG.CreatePoint2d(3, dYCoord), "1.")
sText = "This is note 1."
Set oGeneralNote = oGeneralNotes.AddFitted(oTG.CreatePoint2d(4, dYCoord), sText)
' Two line text. The two lines are defined using the tag within the text string.
dYCoord = dYCoord - (oGeneralNote.FittedTextHeight + 0.5)
Set oGeneralNote = oGeneralNotes.AddFitted(oTG.CreatePoint2d(3, dYCoord), "2.")
sText = "This is note 2, which contains two lines."
' Single line of text.
Set oGeneralNote = oGeneralNotes.AddFitted(oTG.CreatePoint2d(3, dYCoord), "3.")
sText = "This is note 3."
' Three lines of text.
Set oGeneralNote = oGeneralNotes.AddFitted(oTG.CreatePoint2d(3, dYCoord), "4.")
sText = "This is note 4, which contains several lines."
Set oGeneralNote = oGeneralNotes.AddFitted(oTG.CreatePoint2d(3, dYCoord), "5.")
sText = "Here is the last and final line of text."
End Sub
Cheers
