Announcements
iLogic form not updating between open documents when they become active
Does anyone have this issue.
I have created lots of external iLogic rules and when I manually run any of these rules in any open document they all work fine.
To make things easier I created a global form, with which I can press a button and fire the corresponding iLogic rule.
This works well for all rules in a newly opened drawing, but when I move to another already open drawing certain rules don't work. If I close the form and reopen the form in that already open drawing all the rules work again.
I have the event trigger on "open drawing" to fire a rule which loads the form, so if I only open one drawing at a time I have no problems...less than ideal.
All my code is pretty robust, with "thisapplication.activedocument" and " oDoc.ActiveSheet" etc to look only at the current document
Any suggestions?
Using Inv2018.3
64 bit
Replies (23)
Now i do. Thank you for the information
Curtis_Waguespack
Hi @Anonymous,
I'm just adding this in case it helps you or someone else in the future, I think you should be able to use ActiveEditDocument to do this.
As an example try creating an external rule with this simple code in it, and then run it from the global form.
I hope this helps.
Curtis
oDoc = ThisApplication.ActiveEditDocument
sName = oDoc.FullFileName
MessageBox.Show(sName, "iLogic")
Genius, thanks Curtis.
DRoam
FYI for anyone who comes on this thread, I created an Idea for this so it can be tracked as an enhancement request. You can add your vote here: iLogic: Option to close or refresh Global Forms when switching documents.
Here's a photoshopped image I posted of what it might look like:
The "ThisDoc" and "ActiveDocument" workarounds work well for External rules fired from the form, but iProperty fields, parameter fields, and local rule buttons in the form remain stuck linked to the original document the form was fired from. The form needs to refresh between documents for these to reflect or modify on the active document.
