Ilogic fails to talk to Excel
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I am using Inventor 2016, Excel 2013, windows 7 64 bit.
I have very simple iLogic rule:
iwood_supp_thk=GoExcel.CellValue("cc_data.xls", "Sheet1", "wood_supp_thk").
It works well for all other machines. But it fails in one particular machine. The message says:
Error in rule: block4_scenario3, in document: block4_scenario3.ipt
Unable to cast COM object of type 'System.__ComObject' to interface type 'Microsoft.Office.Interop.Excel.Application'. This operation failed because the QueryInterface call on the COM component for the interface with IID '{000208D5-0000-0000-C000-000000000046}' failed due to the following error: Error loading type library/DLL. (Exception from HRESULT: 0x80029C4A (TYPE_E_CANTLOADLIBRARY)).
Looks like the iLogic does not talk to Excel correctly. I re-install Inventor and Excel a couple of times, and use the sequence of installing Office first then Inventor secondly.
Please see attached file for the error message.
What is it? Can somebody help?
Thank you very much!
Limin
Limin
Inventor pro 2023 64 bit update 2.1; Windows 10 pro 64 bit version 21H2; Office 2013 32 bit
