iLogic external rule open files
jacqueline.lima
jacqueline.lima
I need help to generate a .txt file with some infos extracted from all open assemblies. Besides that I need check if a open file is a iAssembly, if yes I need run the rule for all members of this iAssembly. I wrote the code bellow, but it works just for the assembly that are open.
Dim oAssembly As AssemblyDocument = ThisDoc.Document
Dim oCompDef As AssemblyComponentDefinition = oAssembly.ComponentDefinition
Dim IsiAssembly As Boolean = oCompDef.IsiAssemblyFactory()
Dim factory As iAssemblyFactory = oCompDef.iAssemblyFactory
Dim myList, mySelect As New ArrayList
Dim Instalacao
TolMax = InputBox("Qual a tolerância superior do diâmetro de passagem do parafuso?", "Tolerância Superior")
TolMin = InputBox("Qual a tolerância superior do diâmetro de passagem do parafuso?", "Tolerância Superior")
myList.Add("Cemented")
myList.Add("Screwed")
myList.Add("N/A")
myList_selected = InputListBox("Cimentado, Parafusado ou N/A?", myList, myList(0), Title := "Selecione abaixo", ListName := "List")
mySelect.Add(myList_selected)
For Each Instalacao In mySelect
	MessageBox.Show("Arquivo .txt gerado com sucesso! Todos os itens foram definidos como: " & Instalacao, "Sucesso!")
Next
'____Create and write to a text file_________________
oWrite = System.IO.File.CreateText(ThisDoc.Path & "\" & "VerificarConexoes" & ".txt")
'For Each oAssembly In ThisApplication.Documents.VisibleDocuments
For Each assembly As ComponentOccurrence In oCompDef.Occurrences
	oAssembly.Activate()
	oWrite.WriteLine(item & ";" & Round(A, 2) & ";" & Round(B, 2) & ";" & Round(Emax, 2) & ";" & Round(Emin, 2) & ";" & Instalacao)
	If oCompDef.IsiAssemblyFactory() = False Then
		item = iProperties.Value("Project", "Part Number")
		A = Parameter("Ap")
		Emax = Parameter("DIA") + TolMax
		Emin = Parameter("DIA") - TolMin
		B = Parameter("B")
	End If
	If oCompDef.IsiAssemblyFactory() = True Then
		Dim factoryRows As iAssemblyTableRows = factory.TableRows
		For Each row In factoryRows
			A = Parameter("Ap")
			B = Parameter("B")
		Next
	End If
Next
oWrite.Close()
A.Acheson
You can look at the visible document collection.
The ilogic snippet will need to be changed  to a property set version(API) otherwise the part number will be the document you called the rule from rather than the document in your visible documents loop. If you need help constructing just post back with the visible documents loop in place and also the required property set. Any questions ask away.
Regards
Alan
jacqueline.lima
I changed my code for this:
Dim Instalacao
myList.Add("N/A")
'	MessageBox.Show("Arquivo .txt gerado com sucesso! Todos os itens foram definidos como: " & Instalacao, "Sucesso!")
Next
Dim oDoc As Inventor.Document
For Each oDoc In ThisApplication.Documents.VisibleDocuments
	If oDoc.DocumentType = kAssemblyDocumentObject Then
		A = Parameter("Ap")
		B = Parameter("B")
	End If
Next
oWrite.Close()
But still not working. The .txt file that is exporting returns just the infos from the assembly that are visible repeating for all documents opened, as below:
A.Acheson
Here  is some changes removing the ilogic snippets for iproperty and parameters for API versions. The tolerances retrieval may not be correct, so maybe check that section and test.
Dim Instalacao
myList.Add("N/A")
Next
		Dim oAssyDoc As AssemblyDocument = oDoc 'Declare as either an assembly or part to gain access to object collections.
		Dim Params As Parameters = oAssyDoc.ComponentDefinition.Parameters
		Dim opn As [Property]
		opn = oAssyDoc.PropertySets.Item("Design Tracking Properties").Item("Part Number")
		Try
			item = opn.Value.ToString   'cannot use ilogic snippet which is only valid in document the rule is ran from first 'iProperties.Value("Project", "Part Number")
			A = Params("Ap").Value' Value returned in system units cm   'Parameter("Ap")
			Emax = Params("DIA") + TolMax
			Emin = Params("DIA") - TolMin
			B = Params("B")
		Catch
		End Try
	End If
Next
oWrite.Close()
Regards
Alan
jacqueline.lima
It worked!
Thanks a lot!! @A.Acheson
