ilogic export to excel custom properties
idealogicERZYZ
idealogicERZYZ
I have a code snippet exporting Excel. I have described the standard iProperties. I would like to export the "Custom" property "Welding" which is in part files and has a yes or no value.
bRows = oBOMView.BOMRows
For Each bRow In bRows
	Dim rDoc As Document
	rDoc = bRow.ComponentDefinitions.Item(1).Document
	Dim docPropertySet As PropertySet
	docPropertySet = rDoc.PropertySets.Item("Design Tracking Properties")
	xlWorksheet.Range("A" & row).Value = bRow.ItemNumber
	xlWorksheet.Range("C" & row).Value = docPropertySet.Item("Part Number").Value
	xlWorksheet.Range("D" & row).Value = docPropertySet.Item("Description").Value
	xlWorksheet.Range("E" & row).Value = bRow.ItemQuantity
	xlWorksheet.Range("F" & row).Value = docPropertySet.Item("Vendor").Value
	xlWorksheet.Range("P" & row).Value = docPropertySet.Item("Cost").Value
E
JhoelForshav
hi @idealogicERZYZ
See code below :slightly_smiling_face:
	xlWorksheet.Range("A" & Row).Value = bRow.ItemNumber
	xlWorksheet.Range("C" & Row).Value = docPropertySet.Item("Part Number").Value
	xlWorksheet.Range("D" & Row).Value = docPropertySet.Item("Description").Value
	xlWorksheet.Range("E" & Row).Value = bRow.ItemQuantity
	xlWorksheet.Range("F" & Row).Value = docPropertySet.Item("Vendor").Value
	xlWorksheet.Range("P" & Row).Value = docPropertySet.Item("Cost").Value
	'----------------------------Here is what you need-------------------------------------------
	Dim customPropSet As PropertySet
	customPropSet = rDoc.PropertySets.Item("Inventor User Defined Properties")
	'xlWorksheet.Range("Q" & Row).Value = customPropSet.Item("Welding").Value 'If you want True/False
	xlWorksheet.Range("Q" & Row).Value = customPropSet.Item("Welding").Expression 'If you want Yes/No
Next
idealogicERZYZ
Thanks, still a question ...
The script stops if the .ipt part does not have the "Welding" parameter. How to make nothing in the excle tab in the "Q" column? That the parts that do not have this parameter have an empty field in the "Q" column.
E
Sergio.D.Suárez
Hello, adding to the excellent contribution of @JhoelForshav , can you add the instruction try - catch - end try?
You could add it if you don't have an "on error resume next" line before
	Dim rDoc As Document,docPropertySet As PropertySet,customPropSet As PropertySet
	Try
	Catch
	End Try
Next
 I hope this helps with your problem. Regards
Please accept as solution and give likes if applicable.
I am attaching my Upwork profile for specific queries.
Sergio Daniel Suarez
Mechanical Designer
| Upwork Profile | LinkedIn
idealogicERZYZ
Thank you
E
