- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I'm trying to tweak my code (global rule) to export the flat pattern to .sat in format 7.0 (INV2020), it does so but always the folded model. What am I missing???
'On Error GoTo ErrorTrapper:
If iProperties.Value("Project", "Revision Number") = "" Then
iProperties.Value("Project", "Revision Number") = "0"
End If
oRev = iProperties.Value("Project", "Revision Number")
Dim curDoc = ThisApplication.ActiveDocument
If curDoc.SubType = "{9C464203-9BAE-11D3-8BAD-0060B0CE6BB4}" Then
Dim oDoc As PartDocument
oDoc = ThisApplication.ActiveDocument
Dim oCompDef As SheetMetalComponentDefinition
oCompDef = oDoc.ComponentDefinition
'[ Ensure this part has a flat pattern
If oCompDef.FlatPattern Is Nothing Then
oCompDef.Unfold
Else
End If
RuleParametersOutput()
oCompDef.FlatPattern.Edit
Dim sOut As String
Dim sPATH As String
oPathSat = ThisDoc.WorkspacePath() & "\SAT\"
'[ Ensure this folder exist
'Check For the SAT folder And create it If it does Not exist
If Not System.IO.Directory.Exists(oPathSat) Then
System.IO.Directory.CreateDirectory(oPathSat)
End If
Version = 7
Dim sFname As String
sFname = oPathSat & ThisDoc.FileName(False) & "_REV-" & oRev & ".sat"
oDoc.SaveAs(sFname, True)
'oCompDef.SaveAs(sFname ,False)
'oCompDef.DataIO.WriteDataToFile( "ACIS SAT", sFname)
'oCompDef.DataIO.WriteDataToFile( nsOut, nsFname)
oCompDef.FlatPattern.ExitEdit
Else
ThisApplication.StatusBarText = ThisDoc.FileName(False) & " Is not in a sheet metal state, convert to sheetmetal and create flat pattern first --- Jumping to next part"
End If
