iLogic Event Trigger creation to activate update?
Hey Everyone
Can someone assist me with setting an event trigger? the scenario i have is as follows.
I have custom IDW Borders that need to update with the sheet size, with some help i got the rule to change the border when the sheet size is changed, however i need to manually run the rule for the change to take place.
Is there anyway of setting a rule or trigger that when the sheet size is changed, the Local update icon appears and then when you hit update the rule changing the border is run?
I need this to Automate everything so i dont need to manually run the rule each time.
Thanks for your help.
I have attached the IDW
Vladimir.Ananyev
iLogic supports the limited set of events that is shown on the screenshot:
None of them could handle sheet size change.
You could post a request for a solution to this on the Inventor Idea Station to make sure it gets additional support and exposure:
http://forums.autodesk.com/t5/inventor-ideastation/idb-p/v1232
The workaround is to develop an Inventor addin that could handle sheet size changes.
Vladimir Ananyev
Developer Technical Services
Autodesk Developer Network
