iLogic Error
iLogic Error
I've got some code to update the copied iproperties in a drawing that works when run manually but gives an error when triggered.
The code:
Dim oControlDef as ControlDefinition
oControlDef = ThisApplication.CommandManager.ControlDefinitions.​Item("UpdateCopiedModeliPropertiesCmd")
oControlDef.Execute2(True)
Thanks!
bradeneuropeArthur
Change this:
oControlDef.Execute
Arthur Knoors
Autodesk Affiliations:
Programming Examples:Drawing List!|Toggle Drawing Sheet!|Workplane Resize!|Drawing View Locker!|Multi Sheet to Mono Sheet!|Drawing Weld Symbols!|Drawing View Label Align!|Open From Balloon!|Model State Lock!
Posts and Ideas:Dimension Component!|Partlist Export!|Derive I-properties!|Vault Prompts Via API!|Vault Handbook/Manual!|Drawing Toggle Sheets!|Vault Defer Update!
