iLogic Error Help!!
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hi Guys,
I am receiving an error after the "cancel" button event on an input box.
The rule runs fine when entering a value into the inputbox.
But, after the inputbox is cancelled, the next time it is run, it gives the following error. I have pasted the code below.
Please any help, I have searched for help on vb and ilogic and I can't find anything!
Error in rule: ISSUE REVISION, in document: ILOGIC.ipt
Object reference not set to an instance of an object.
(More Info)
System.NullReferenceException: Object reference not set to an instance of an object.
at iLogic.GoExcel.SetCurrentSheet(String fileName, String sheetName)
at iLogic.GoExcel.GetCell(String cellAddress)
at iLogic.GoExcel.get_CurrentCellValue(String cellAddress)
at LmiRuleScript.Main()
at Autodesk.iLogic.Exec.AppDomExec.ExecRuleInAssembly(Assembly assem)
at iLogic.RuleEvalContainer.ExecRuleEval(String execRule)
Format:HTML Format Version:1.0 StartHTML: 165 EndHTML: 49705 StartFragment: 314 EndFragment: 49673 StartSelection: 314 EndSelection: 314SyntaxEditor Code Snippet
'Setup .ipt parameters Section = Left(Parameter("SECTION"),1) 'Type (mechanical, Fluid) Struct = Left(Parameter("STRUCTURE"),1) 'Assembly or Component 'define the file to create/open Worksheet = "Z:\CAD\DESIGN ENVIRONMENT\iLogic\PN.xlsx" Sheetno = ("Sheet1") 'check for existing file If Dir(Worksheet) <> "" Then 'workbook exists, open it GoExcel.Open(Worksheet, Sheetno) 'save current iproperty value OldRevisionNumber = iProperties.Value("Project", "Revision Number") 'set new revision number to input box value NewRevisionNumber = InputBox("Enter the new Revision Number e.g. B", "iLogic", NewRevisionNumber) If NewRevisionNumber = "" Then 'catch an empty input or user pressing cancel button MessageBox.Show("Please Enter a Valid Revision Number", "Error Handler ") Return Else End If 'store revision number in iproperties iProperties.Value("Project", "Revision Number") = NewRevisionNumber ' Open excel GoExcel.Open(Worksheet, Sheetno) ' Define Range RowStart = 2 RowEnd = 10000 'Find the first empty cell For count = RowStart To RowEnd ' If it's blank count it If String.IsNullOrEmpty(GoExcel.CellValue("C" & count)) Then ' Row Number is equal to the current row rowN = count 'Exit For loop Exit For End If Next MessageBox.Show("Inserting Data on Row " & rowN, "Updating Database...") ' Enter & Read values back from Excel Spreadsheet Filename = iProperties.Value("Project", "Part Number") & iProperties.Value("Project", "Revision Number")& "_" & iProperties.Value("Project", "Description") GoExcel.CellValue("C" & RowN) = iProperties.Value("Project", "Part Number") GoExcel.CellValue("D" & RowN) = iProperties.Value("Project", "Revision Number") GoExcel.CellValue("E" & RowN) = iProperties.Value("Project", "Description") GoExcel.CellValue("F" & RowN) = Filename iProperties.Value("Project", "Designer") = iProperties.Value("Summary", "Author") Filename = GoExcel.CellValue("F" & rowN) 'save excel GoExcel.Save MessageBox.Show("Your Unique Part Number is " & Filename, "Updating Database...") ' ' 'define the active document oDoc = ThisDoc.Document 'create a file dialog box Dim oFileDlg2 As inventor.FileDialog = Nothing InventorVb.Application.CreateFileDialog(oFileDlg2) 'check file type and set dialog filter If oDoc.DocumentType = kPartDocumentObject Then oFileDlg2.Filter = "Autodesk Inventor Part Files (*.ipt)|*.ipt" Else If oDoc.DocumentType = kAssemblyDocumentObject Then oFileDlg2.Filter = "Autodesk Inventor Assembly Files (*.iam)|*.iam" Else If oDoc.DocumentType = kDrawingDocumentObject Then oFileDlg2.Filter = "Autodesk Inventor Drawing Files (*.idw)|*.idw" End If 'set the directory to open the dialog at oFileDlg2.InitialDirectory = ThisDoc.WorkspacePath() 'set the file name string to use in the input box oFileDlg2.FileName = Filename 'work with an error created by the user backing out of the save oFileDlg2.CancelError = True On Error Resume Next 'specify the file dialog as a save dialog (rather than a open dialog) oFileDlg2.ShowSave() 'catch an empty string in the imput If Err.Number <> 0 Then 'MessageBox.Show("No File Saved.", "iLogic: Dialog Canceled") 'Enter Code which removes last entry from Spreadsheet if cancelled GoExcel.Open(Worksheet, Sheetno) For count = RowStart To RowEnd ' If it's blank count it If String.IsNullOrEmpty(GoExcel.CellValue("C" & count)) Then ' Last entry was on bottom row minus 1 rowN = count -1 'Exit For loop Exit For End If Next 'if cancelled, iProperties.Value("Project", "Revision Number") = OldRevisionNumber 'Clear entries in these rows for unsaved part GoExcel.CellValue("A" & rowN) = "" GoExcel.CellValue("B" & rowN) = "" GoExcel.CellValue("C" & rowN) = "" GoExcel.CellValue("D" & rowN) = "" GoExcel.CellValue("E" & rowN) = "" GoExcel.CellValue("F" & rowN) = "" GoExcel.Save MessageBox.Show("No File Saved." &vbLf & "Removing Last Entry From Database...") ElseIf oFileDlg2.FileName <> "" Then MyFile = oFileDlg2.FileName 'save the file oDoc.SaveAs(MyFile, False) 'True = Save As Copy & False = Save As End If iLogicVb.UpdateWhenDone = True Else MessageBox.Show("Excel Failed to Open." &vbLf & "Ensure Engineering Root is mapped to Z:/", "Error Handler") End If
