iLogic drawing view controls in drawing files
tonychristman4915
tonychristman4915
Hello all,
I'm looking for how to use inventor iLogic to activate and deactivate the "Definition in Base View" option for drawing views. This is found by double clicking on a drawing view and selecting the "Display Options" tab.
I have a drawing file that uses an iLogic rule to activate and place section views but I want to give the option to our engineering staff to change the locations of the section views, then run a rule that hides all the arrows that clog up the Base view without having to click on every view manually.
The closest post I've found was this one: http://forums.autodesk.com/t5/inventor-general-discussion/ilogic-make-drawing-view-shaded/td-p/37586... that discussed how to use iLogic to change the view style, however I haven't discovered how to control the "Definiton in Base View" option yet.
Thanks!
Replies (7)
Curtis_Waguespack
Hi tonychristman4915,
Here's a quick example based on the one at the link you provided.
I hope this helps.
Curtis
Dim oDrawDoc As DrawingDocument
 oDrawDoc = ThisApplication.ActiveDocument
Dim oSheet As Sheet
oSheet = oDrawDoc.ActiveSheet
' select drawing views on active sheet
Dim oDrawView As DrawingView
For Each oDrawView In oSheet.DrawingViews
	'adjust drawing view
	If oDrawView.ViewType = DrawingViewTypeEnum.kDetailDrawingViewType Then
		'toggle detail view fence visiblility
		If oDrawView.DisplayDefinitionInBase = False Then
		oDrawView.DisplayDefinitionInBase = True
		Else
		End If
	End If
Next
' **** DrawingViewTypeEnums ****
'	kAssociativeDraftDrawingViewType = 10506
'	kAuxiliaryDrawingViewType = 10499
'	kCustomDrawingViewType = 10498
'	kDefaultDrawingViewType = 10497
'	kDetailDrawingViewType = 10502
'	kDraftDrawingViewType = 10505
'	kOLEAttachmentDrawingViewType = 10500
'	kOverlayDrawingViewType = 10507
'	kProjectedDrawingViewType = 10504
'	kSectionDrawingViewType = 10503
'	kStandardDrawingViewType = 10501
Curtis_Waguespack
Here's another example that turns off sections arrows/lines for sections views:
Dim oSheet As Sheet
	'look for section views
	If oDrawView.ViewType = DrawingViewTypeEnum.kSectionDrawingViewType Then
		'turn off section view annotations
	End If
Next
tonychristman4915
This worked perfectly and was exactly what I was looking for. Thanks!
LSKELLY
Hi Curtis
I have been looking for a way to change the Model State of a DrawingView object. I can't find any settings in the object browser. Any chance I am missing it under an obscure name?
I half expect it to look something like:
oDrawView.ModelState = "Machining"
Lance Skelly
LSKELLY
Don't worry I found it. The following snippet illustrates how to change the Model State of a weldment view.
'Create View
oBaseView = oSheet.DrawingViews.AddBaseView(oPartDoc, oPoint1, ViewScale, ViewOrientationTypeEnum.kIsoTopRightViewOrientation, DrawingViewStyleEnum.kHiddenLineRemovedDrawingViewStyle)
'View Settings
oBaseView.DisplayForeshortenedTangentEdges = True
If oPartDoc.DocumentSubType.DocumentSubTypeID = "{28EC8354-9024-440F-A8A2-0E0E55D635B0}" 'If Weldment
    oBaseView.SetWeldmentState(WeldmentStateEnum.kMachiningWeldmentState)
End If
dbushDQ3RE
HI Guts,
Making the view is one thing, put how do I access the (Welds Model State) and the (Welds components) in that view to Make Dimensions on named Faces using ILogic. I can make Dimensions for the (Assembly Model State) and its Components). ........
A.Acheson
Hi @dbushDQ3RE
I would suggest to make a new post as this original post is solved and relates to a very generic question "iLogic drawing view controls in drawing files"
Your question relates to multiple questions each likely deserving its own post due to there complications.
Regards
Alan
