iLogic - doesn't close opened document
j.pavlicek
j.pavlicek
Hello, I have simple procedure for reading name of title block used in template.
Dim oTemplate As DrawingDocument
Dim sTitleBlockName As String
'Opens template
oTemplate = ThisApplication.Documents.Open(ThisDrawing.ResourceFileName, False)
'Name of used title block
sTitleBlockName = oTemplate.ActiveSheet.TitleBlock.Name
'closes tamplate
oTemplate.Close(true)
'Sets actual title block
ActiveSheet.TitleBlock = sTitleBlockName
But when I run this code (without any error), and try to create a new drawing, I get msg with text: "The template file is open. Please close it and try again."
What is wrong with my code?
PS: I tried to comment last line and it works. I think that sTitleBlockName is somehow connected to template file instead to read its Name value.
PPS: Moving line with file closing on the end solve my problem, but still. Is possible to use sTitleBlockName with closed template?
Inventor 2022, Windows 10 Pro
Sorry for bad English.
machiel.veldkamp
Try this:
oTemplate.Close(false)
___________________________
j.pavlicek
This means - save template document. I don't want it. See This means - save template document. I don't want it. See http://help.autodesk.com/view/INVNTOR/2020/ENU/?guid=GUID-6BBD0D08-7C06-46B1-9E3E-http://help.autode...
