iLogic Design Copy - make multiple copies?
Hi everyone!
I am wondering if anyone has automated making multiple copies with the iLogic Design Copy tool.
I make 10 to 15 copies almost every time I use this tool and it has become quite tedious.  Is there a way to automate this for multiple copies? The only change for each iteration is an incrementing prefix (i.e. "30_01_", "30_02_").
Any suggestions?
Ooops! Wrong forum.
Re-posted in customization forum.
clive.w66LR9
I know its old but this might help someone, this only works if you run it from within a assembly that contains the assembly you want to copy and the code is a mess.
' Display a message box to the user with instructions
Dim userResponse = MessageBox.Show("To use this function a few things to note:" & vbNewLine & _
    "   - You use it from the Main Assembly, not from the assembly you want to copy" & vbNewLine & _
    "   - It doesn't work for assemblies within assemblies", "Frametek Ilogic Copy V.1.0", MessageBoxButtons.OKCancel)
' If the user clicked OK in the message box
If userResponse = vbOK Then
    ' Prompt the user to pick the assembly to copy
    Dim pickedAssembly As Object
    pickedAssembly = ThisServer.CommandManager.Pick(SelectionFilterEnum.kAssemblyOccurrenceFilter, "Pick Assembly To Copy")
    ' Cast the picked assembly as a Document
    Dim pickedDocument As Document
    pickedDocument = pickedAssembly.Definition.Document
    ' Get the filename of the picked document
    Dim pickedDocFileName As String = Right(pickedDocument.FullDocumentName, (Len(pickedDocument.FullDocumentName) - (Left(pickedDocument.FullDocumentName, Len(pickedDocument.FullDocumentName)).LastIndexOf("\") + 1)))
    MessageBox.Show(pickedDocFileName , "Title")
    ' Ask the user how many copies they would like
    Dim numCopies = InputBox("How many times would you like to copy the assembly?", "How Many Copies?", "1")
    ' Set a prefix for the copied files
    Dim filePrefix As Integer = 0
    ' Loop to create the copies
    Do
        filePrefix += 1
        ' For each copy
        For i = 1 To numCopies
            ' Determine the save location for the copied assembly
            Dim saveLocation As String
            saveLocation = Left(pickedDocument.FullFileName, Len(pickedDocument.FullFileName) - 4) & "" & filePrefix & ".iam"
            ' If a file already exists at the save location, skip to the next iteration
            If System.IO.File.Exists(saveLocation) Then
                Continue Do
            End If
            ' Save a copy of the picked document
            pickedDocument.SaveAs(saveLocation, True)
            ' Open the copied document
            Dim copiedDoc As Document
            copiedDoc = ThisApplication.Documents.Open(saveLocation, False)
            ' Get the component definition of the copied document
            Dim copiedDocCompDef As AssemblyComponentDefinition = copiedDoc.ComponentDefinition
            ' For each component occurrence in the copied document
            For Each compOcc As ComponentOccurrence In copiedDocCompDef.Occurrences
                ' If the component occurrence name does not end with ":1", skip to the next iteration
                If Right(compOcc.Name, 2) <> ":1" Then
                    Continue For
                End If
                ' Open the referenced document of the component occurrence
                Dim refDoc As Document = ThisApplication.Documents.Open(compOcc.ReferencedDocumentDescriptor.FullDocumentName, False)
                ' Determine the save location for the referenced document
                Dim refDocSaveLocation As String = Left(refDoc.FullFileName, (Left(refDoc.FullFileName, Len(refDoc.FullFileName)).LastIndexOf("\") + 2)) & _
                    Left(Strings.Mid(refDoc.FullFileName, (Left(refDoc.FullFileName, Len(refDoc.FullFileName)).LastIndexOf("\") + 2)), Len(Strings.Mid(refDoc.FullFileName, (Left(refDoc.FullFileName, Len(refDoc.FullFileName)).LastIndexOf("\") + 2))) - 4) & _
                    "_" & filePrefix & ".ipt"
                If System.IO.File.Exists(refDocSaveLocation) Then
                    Continue For
                End If
                ' Save a copy of the referenced document
                refDoc.SaveAs(refDocSaveLocation, True)
                ' Replace the component occurrence with the copied referenced document
                compOcc.Replace(refDocSaveLocation, True)
                refDoc.Close()
            Next
            ' Update and save the copied document
            copiedDoc.Update()
            copiedDoc.Save()
            copiedDoc.Close()
        Next
    Loop Until filePrefix >= numCopies
End If
