- Mute
- Permalink
- Report
I am trying to create overall width and length dimensions in all views of a sheet.
I found a code on the web that will do the work for an individual view when clicking on it, I tried to modified it to run in all views of a sheet but it is not working right now.
Public Class ThisRule ' This code was written by Jelte de Jong ' and published on www.hjalte.nl Private _doc As DrawingDocument Private _sheet As Sheet Private _view As DrawingView Private _intents As List(Of GeometryIntent) = New List(Of GeometryIntent)() Sub Main() _doc = ThisDoc.Document _sheet = _doc.ActiveSheet ' _view = ThisApplication.CommandManager.Pick( ' SelectionFilterEnum.kDrawingViewFilter, ' "Select a drawing view") For Each _view In thisapplication.ActiveDocument.Activesheet.drawingviews 'This is the line I created to run in all views CreateIntentList() CreateIntentList() createHorizontalOuterDimension() createVerticalOuterDimension() Next End Sub Private Sub createHorizontalOuterDimension() Dim orderedIntents = _intents.OrderByDescending(Function(s) s.PointOnSheet.X) Dim pointLeft = orderedIntents.First Dim pointRight = orderedIntents.Last Dim textX = pointLeft.PointOnSheet.X + (pointRight.PointOnSheet.X - pointLeft.PointOnSheet.X) / 2 Dim textY = _view.Position.Y + _view.Height / 2 + 2 Dim pointText = ThisApplication.TransientGeometry.CreatePoint2d(textX, textY) _sheet.DrawingDimensions.GeneralDimensions.AddLinear( pointText, pointLeft, pointRight, DimensionTypeEnum.kHorizontalDimensionType) End Sub Private Sub createVerticalOuterDimension() Dim orderedIntents = _intents.OrderByDescending(Function(s) s.PointOnSheet.Y) Dim pointLeft = orderedIntents.Last Dim pointRight = orderedIntents.First Dim textY = pointLeft.PointOnSheet.Y + (pointRight.PointOnSheet.Y - pointLeft.PointOnSheet.Y) / 2 Dim textX = _view.Position.X - _view.Width / 2 - 2 Dim pointText = ThisApplication.TransientGeometry.CreatePoint2d(textX, textY) _sheet.DrawingDimensions.GeneralDimensions.AddLinear( pointText, pointLeft, pointRight, DimensionTypeEnum.kVerticalDimensionType) End Sub Private Sub addIntent(Geometry As DrawingCurve, IntentPlace As Object, onLineCheck As Boolean) Dim intent As GeometryIntent = _sheet.CreateGeometryIntent(Geometry, IntentPlace) If intent.PointOnSheet Is Nothing Then Return If onLineCheck Then If (IntentIsOnCurve(intent)) Then _intents.Add(intent) End If Else _intents.Add(intent) End If End Sub Private Function IntentIsOnCurve(intent As GeometryIntent) As Boolean Dim Geometry As DrawingCurve = intent.Geometry Dim sp = intent.PointOnSheet Dim pts(1) As Double Dim gp() As Double = {} Dim md() As Double = {} Dim pm() As Double = {} Dim st() As SolutionNatureEnum = {} pts(0) = sp.X pts(1) = sp.Y Try Geometry.Evaluator2D.GetParamAtPoint(pts, gp, md, pm, st) Catch ex As Exception Return False End Try Return True End Function Private Sub CreateIntentList() For Each oDrawingCurve As DrawingCurve In _view.DrawingCurves Select Case oDrawingCurve.ProjectedCurveType Case _ Curve2dTypeEnum.kCircleCurve2d, Curve2dTypeEnum.kCircularArcCurve2d, Curve2dTypeEnum.kEllipseFullCurve2d, Curve2dTypeEnum.kEllipticalArcCurve2d addIntent(oDrawingCurve, PointIntentEnum.kCircularTopPointIntent, True) addIntent(oDrawingCurve, PointIntentEnum.kCircularBottomPointIntent, True) addIntent(oDrawingCurve, PointIntentEnum.kCircularLeftPointIntent, True) addIntent(oDrawingCurve, PointIntentEnum.kCircularRightPointIntent, True) addIntent(oDrawingCurve, PointIntentEnum.kEndPointIntent, False) addIntent(oDrawingCurve, PointIntentEnum.kStartPointIntent, False) Case _ Curve2dTypeEnum.kLineCurve2d, Curve2dTypeEnum.kLineSegmentCurve2d addIntent(oDrawingCurve, PointIntentEnum.kEndPointIntent, False) addIntent(oDrawingCurve, PointIntentEnum.kStartPointIntent, False) Case _ Curve2dTypeEnum.kPolylineCurve2d, Curve2dTypeEnum.kBSplineCurve2d, Curve2dTypeEnum.kUnknownCurve2d ' Unhandled curves types Case Else End Select Next End Sub ' Copyright 2021 ' ' This code was written by Jelte de Jong, and published on www.hjalte.nl ' ' Permission Is hereby granted, free of charge, to any person obtaining a copy of this ' software And associated documentation files (the "Software"), to deal in the Software ' without restriction, including without limitation the rights to use, copy, modify, merge, ' publish, distribute, sublicense, And/Or sell copies of the Software, And to permit persons ' to whom the Software Is furnished to do so, subject to the following conditions: ' ' The above copyright notice And this permission notice shall be included In all copies Or ' substantial portions Of the Software. ' ' THE SOFTWARE Is PROVIDED "AS IS", WITHOUT WARRANTY Of ANY KIND, EXPRESS Or IMPLIED, ' INCLUDING BUT Not LIMITED To THE WARRANTIES Of MERCHANTABILITY, FITNESS For A PARTICULAR ' PURPOSE And NONINFRINGEMENT. In NO Event SHALL THE AUTHORS Or COPYRIGHT HOLDERS BE LIABLE ' For ANY CLAIM, DAMAGES Or OTHER LIABILITY, WHETHER In AN ACTION Of CONTRACT, TORT Or ' OTHERWISE, ARISING FROM, OUT Of Or In CONNECTION With THE SOFTWARE Or THE USE Or OTHER ' DEALINGS In THE SOFTWARE. End Class
