ilogic - create a .zip file
has anyone ever used ilogic to create a .zip?
Currently we export pdf and dxf upon file release and was wondering if anyone has done similar and managed to create a zip file of their exported docs?
thx in advance
ekinsb
iLogic provides a somewhat simplified interface to the Inventor API and Visual Basic.  However, because it's using the .NET engine you have full access to the capabilities of the .NET framework, which does support creating zip archives.  Here's a rule that zips up the contents of the folder "C:\Temp\AnswerDay" and creates the archive "C:\Temp\AnswerDay.zip"
AddReference "System.IO.Compression"
AddReference "System.IO.Compression.FileSystem"
If System.IO.File.Exists("C:\Temp\AnswerDay.zip")
    System.IO.File.Delete("C:\Temp\AnswerDay.zip")
System.IO.Compression.ZipFile.CreateFromDirectory("C:\Temp\AnswerDay", "C:\Temp\AnswerDay.zip")
Brian Ekins
Mod the Machine blog
hi brian
that seems to work, it does create the zip file, but throws an error afterwards
" the process cannot access the file "C:\temp\xxxx.zip" because it is being used by another process.
any ideas on how to resolve and remove the error?
many thanks for your input!
adam.nagy
Autodesk Support
Autodesk Support
"but throws an error afterwards"
When exactly does the error appear?
Are you trying to do something with the zip afterwards in your code?
Could you please try to narrow down the issue to a minimal sample?
Adam Nagy
Autodesk Platform Services
