iLogic component replace within nested subassemblies
To start off, I'm new to iLogic.
I'm looking to replace all ipt files of a certain name with my own file. I believe I have a working ilogic rule that allows me to do just that. My problem is this rule only works within a single iam file, searching for an ipt and replacing it. I need this rule to propagate from a high level assembly and search all assembly files, sometimes two or three tier nested assemblies.
This is what I've managed to come up with that seems to work within a single assembly file.
oOccurrences = ThisDoc.Document.ComponentDefinition.Occurrences
For Each oComp As ComponentOccurrence In oOccurrences
    oCompName = oComp.Name
    If InStr(oCompName, "PnC") > 0 Then
        Component.Replace(oCompName,"Weld.ipt", True)
    End If
Next
Xun.Zhang
Try the sample below via API.
Replace all sub assembly which include Collar.ipt and replace it.
Sub Main()
    'Component.Replace("CollarBottomPlate:1", "Collar.ipt", True)
    Dim doc As AssemblyDocument
    doc = ThisApplication.ActiveDocument
    Dim strFileName As String
    strFileName = "Collar:"
    Dim strPath As String
    strPath = "C:\TEMP\iLogicTest\GA\CollarBottomPlate.ipt"
    Dim oOcc As ComponentOccurrence
    For Each oOcc In doc.ComponentDefinition.Occurrences
        Call ReplaceOccurrence(strFileName, strPath, oOcc)
    Next
End Sub
Sub ReplaceOccurrence(strFileName As String, strPath As String, oOcc As ComponentOccurrence)
    If InStr(oOcc.Name,strFileName)>0 Then
        Call oOcc.Replace(strPath, False)
    End If
    Dim osubOcc As ComponentOccurrence
    If oOcc.SubOccurrences.Count > 0 Then
        For Each osubOcc In oOcc.SubOccurrences
            Call ReplaceOccurrence(strFileName, strPath, osubOcc)
        Next
    End If
End Sub
another example like to replace Collar.ipt in every assembly
Sub Main()
    strFileName = "Collar:1"
    Next
End Sub
    If oOcc.Name = strFileName Then
    End If
        Next
    End If
End Sub
Hope it helps!
Xun
I can see how this would work for a simple single file with a known file path. I've been trying to figure out a way to alter this to work for me.
an example of the file names I have would be "PnC_Geometry_Spot_80000_01_R"
The "80000_01" would be different for each file.
I would have to keep an "If InStr" condition to call out only a portion of the file name, with each "PnC" file path unknown.
I think the last example I received may be a helpful template and I'll keep playing with it and see what I can come up with.
Thanks for the help so far!
