iLogic Coding of 500x500 square sketch
solomon7JX9D
solomon7JX9D
Can anyone solve this code to create a rectangle using iLogic?
It tells me the 'Origin' on 'PlanarSketch' not found.
' Get the active document
Dim invDoc As Inventor.Document = ThisApplication.ActiveDocument
' Get the active sketch plane
Dim sketchPlane As PlanarSketch = invDoc.ComponentDefinition.Sketches.Add(invDoc.ComponentDefinition.WorkPlanes.Item(3))
' Define rectangle dimensions
Dim rectangleWidth As Double = 500
Dim rectangleHeight As Double = 500
' Set the origin of the sketch plane to (0,0,0)
sketchPlane.Origin = ThisApplication.TransientGeometry.CreatePoint(0, 0, 0)
' Create the rectangle
Dim startPoint As SketchPoint = sketchPlane.SketchPoints.Add(ThisApplication.TransientGeometry.CreatePoint2d(0, 0))
Dim endPoint As SketchPoint = sketchPlane.SketchPoints.Add(ThisApplication.TransientGeometry.CreatePoint2d(rectangleWidth, rectangleHeight))
Dim line1 As SketchLine = sketchPlane.SketchLines.AddByTwoPoints(startPoint, sketchPlane.SketchPoints.Add(ThisApplication.TransientGeometry.CreatePoint2d(rectangleWidth, 0)))
Dim line2 As SketchLine = sketchPlane.SketchLines.AddByTwoPoints(line1.EndSketchPoint, endPoint)
Dim line3 As SketchLine = sketchPlane.SketchLines.AddByTwoPoints(endPoint, sketchPlane.SketchPoints.Add(ThisApplication.TransientGeometry.CreatePoint2d(0, rectangleHeight)))
Dim line4 As SketchLine = sketchPlane.SketchLines.AddByTwoPoints(line3.EndSketchPoint, startPoint)
' Update the sketch
sketchPlane.Update()
petr.meduna
PlanarSketch has OriginPoint where you can set workpoint, vertex or sketchpoint. So, use default workpoint instead.
sketchPlane.OriginPoint = invDoc.ComponentDefinition.workpoints.Item(1)
Also, you cannot update sketch, only document.
invDoc.Update()
