Ilogic Code to Show Dimensions of an Assembly
el_jefe_de_steak
el_jefe_de_steak
I would like to see the maximum dimensions of an assembly. How can I do this with iLogic?
el_jefe_de_steak
Here is the code I found on another forum post that will do this for you.
Dim dims(0 To 2) As Decimal
dims(0) = Measure.ExtentsLength
dims(1) = Measure.ExtentsHeight
dims(2) = Measure.ExtentsWidth
MessageBox.Show("Complete" & vbLf & "Length: " & dims(0).ToString & vbLf & "Width: " & dims(1).ToString & vbLf & "Height: " & dims(2).ToString, "Get Size")
machiel.veldkamp
Try this:
Public Sub Main()
	Dim oDoc As AssemblyDocument
	oDoc = ThisApplication.ActiveDocument
	Dim i As Integer	'Use i as a counter.
	Dim param As Parameter
	Dim CurrentValue As Double
	Dim BigValue As Double = 0
	Dim ParamName As String
	' loop through all parameters
	For Each param In oDoc.ComponentDefinition.Parameters
		CurrentValue = param.Value
		If CurrentValue > BigValue
			BigValue = CurrentValue
			ParamName = param.Name
		End If
	Next
	MessageBox.Show(ParamName & " is the biggest parameter with a value of: " & BigValue * 10 & "mm", "Test123") 'I do BigValue * 10 to convert from cm to mm.
End Sub
___________________________
el_jefe_de_steak
The question is meant to be in regards to the overall lengths of an assembly. Sorry for not clarifying that...
I think it's a little cleaner and less code to just show the maximum of an array than to use an if loop to find the largest value. However, this approach does not work in some instances.
Dim dimensionArray(0 To 2) As Decimal
dimensionArray(0) = Measure.ExtentsLength
dimensionArray(1) = Measure.ExtentsHeight
dimensionArray(2) = Measure.ExtentsWidth
MessageBox.Show("The maxiumum size of this assembly is: " & dimensionArray.Max.ToString & " in")
