iLogic Code to rename sheets
I'm trying to figure out how to Rename the sheets of a drawing using iLogic. I want to have a message box open and you would enter the number of sheets you want want and the number to start those sheets at renamed at the top to E100, E101, E102, E103 (Say 4 would be erection sheets showing overall assembly) - then have the remaining sheets renamed starting at a InputBox entry number - (if 200 was input) the sheets would number 200, 201, 202,.....
So you would start with
Input Box - How many Erection Sheets = ?
Input Box - Erection Sheet number start = ?
then
Rename remaining sheets - Input Box starting number - ?
Any help would be appreciated greatly.
Thanks.
marcin_otręba
Maybe you can start from this. It will rename all selected sheets in your drawing with input value:
Just select some sheets in your drawing and run rule.
Dim odrw As DrawingDocument = ThisDoc.Document
Dim oselset As SelectSet = odrw.SelectSet
Dim osheet As Sheet
If oselset.Count <> 0 Then
	myparam = InputBox("Enter start value for renaming selected sheets", "Rename", "Default Entry")
	If IsNumeric(myparam) Then
		prefix=""
		counter = myparam
		Else
If  Left(myparam, 1)="E" Then
prefix="E"
		counter = Replace(myparam,"E","")
End If
		End If
For Each osheet In  oselset
	osheet.Name = prefix & counter
	counter=counter+1
Next
End If
Hi, maybe you want to check my apps:
DrawingTools   View&ColoringTools   MRUFolders
