iLogic code Nested If
Hi.
I have a bit of code that checks dimensions in an idw to find out if they should display to 1 decimal place or rounded depending on their value, e.g. 20.2 displays as 20.2 but 20.0 displays as 20.
Dim oDoc As DrawingDocument = ThisDoc.Document
Dim oSheet As Sheet = oDoc.ActiveSheet
For Each oDim As DrawingDimension In oSheet.DrawingDimensions
	If Round(oDim.ModelValue * 10, 1) -Round(oDim.ModelValue * 10, 0) = 0 Then
		oDim.Precision = 0
	Else
		oDim.Precision = 1
	End If
Next
I want to add in another check to see if the dimension is <= 499.4 and then, based on the result:
1.  If it is above 499.4 it displays rounded (e.g. 499.5 displays as 500).
2.  If it is <=499.4 then it follows the previous rule and displays to a precision of either 0 or 1.
This was one of my attempts:
	If oDim.ModelValue > 499.4 Then
		oDim.Precision = 0
		Else
		oDim.Precision = 0
		Else
		oDim.Precision = 1
	End If
	End If
Next
......... but no joy.
Could anybody please advise the best way to do this?
T
WCrihfield
Have you considered that the 499.4 raw number you are supplying may be getting understood as 'database units', instead of your intended 'document' units?  This is a fairly well known issue that a ton of us wish we could eliminate, once and for all, but it persists, due to global use.  Any raw numbers specified within the code, that are in a 'length' scenario, are usually understood by the 'system' as 'database units' (centimeters), instead of whatever length units you may be using within your document.
Try this (set-up to ensure the 499.4 is understood as Inches):  (you could also just use some simple math)
Sub Main
		If oDim.ModelValue <= UnitConv(499.4, UnitsTypeEnum.kInchLengthUnits) Then
				oDim.Precision = 0
			Else
				oDim.Precision = 1
			End If
		Else
			oDim.Precision = 0
		End If
	Next
End Sub
Function UnitConv(oVal As Double, oIntendedUnits As UnitsTypeEnum) As Double
	'just set up to deal with 'Length' type units right now
	'this converts your Inches input to 'database units' so the rule will understand it as intended
	Return ThisApplication.UnitsOfMeasure.ConvertUnits(oVal, oIntendedUnits, UnitsTypeEnum.kDatabaseLengthUnits)
End Function
If this solved your problem, or answered your question, please click ACCEPT SOLUTION.
Or, if this helped you, please click (LIKE or KUDOS) :thumbs_up:.
If you want and have time, I would appreciate your Vote(s) for My IDEAS :light_bulb:or you can Explore My CONTRIBUTIONS
Wesley Crihfield
(Not an Autodesk Employee)
Hi.
Thanks very much for your response.  This did the trick!
My units are mm so I just changed the 499.4 to 49.94 and bingo!  I wasn't aware of the units issue so thanks for that.
This is how the code finished up:
Sub Main
		If oDim.ModelValue <= 49.94 Then
				oDim.Precision = 0
			Else
				oDim.Precision = 1
			End If
		Else
			oDim.Precision = 0
		End If
	Next
End Sub
Thanks very much for your help!
Cheers,
T
